I have an 8 relay board I am using to power multiple plugs and I want to invert the state to Home Assistant. I thought adding inverted: yes to the ESPHome side would invert the state sent to HA, but it seems HA is not reflecting the inverted state but the raw toggle. Is there an easy way to do this without making a binary sensor to control the invert?
Here I have relay 1 setup normal (On is On and Off is Off) and then I have relay 2 as inverted as another test. I have restart HA, removed and re-added the ESPhome module but nothing seems to work to update the state to match what I need (Relay Off is On, Relay On is Off).
So if that is the case I want to not use inverted on the ESPHome side since I’m using a normally closed side of the relay. I only want the relay energized in the few occasions I want to kill power to the socket.
So would I need to use a customize or template to invert this in HA to logically reflect an on and off state for the device plugged in?
Yes silly mistake. Once I removed the inverted flag the relay flipped back and the states matched up as expected. I think I was looking at this way too long in all the testing and changes.
