Hi all,
I have just connected up a ESP32 board to an AliExpress 4-relay board which requires a UART communication to turn the relays on and off. What I have so far is this:
uart:
tx_pin: GPIO5
baud_rate: 115200
switch:
turn_on_action:
- uart.write: [0xA0, 0x01, 0x01, 0xA2]
turn_off_action:
- uart.write: [0xA0, 0x01, 0x00, 0xA1]
turn_on_action:
- uart.write: [0xA0, 0x02, 0x01, 0xA3]
turn_off_action:
- uart.write: [0xA0, 0x02, 0x00, 0xA2]
turn_on_action:
- uart.write: [0xA0, 0x03, 0x01, 0xA4]
turn_off_action:
- uart.write: [0xA0, 0x03, 0x00, 0xA3]
turn_on_action:
- uart.write: [0xA0, 0x03, 0x01, 0xA5]
turn_off_action:
- uart.write: [0xA0, 0x03, 0x00, 0xA4]
This actually works reasonably well, clicking the entity switch in Home Assistant turns the relay on. The issue is that after a couple of seconds, Home Assistant sets the switch state to ‘Off’ for no apparent reason? The relay is left open, so now the states mismatch the hardware.
Any ideas what’s wrong with the code?
Thanks!
