INFO ESPHome 2024.4.0
INFO Reading configuration /config/esphome/gatekeeper.yaml...
WARNING 'garage_door_opener': Using the '_' (underscore) character in the hostname is discouraged as it can cause problems with some DHCP and local name services. For more information, see https://esphome.io/guides/faq.html#why-shouldn-t-i-use-underscores-in-my-device-name
INFO Starting log output from 192.168.1.39 using esphome API
INFO Successfully connected to garage_door_opener @ 192.168.1.39 in 0.103s
INFO Successful handshake with garage_door_opener @ 192.168.1.39 in 0.025s
[14:49:11][I][app:100]: ESPHome version 2024.4.0 compiled on Apr 22 2024, 14:04:26
[14:49:11][C][wifi:580]: WiFi:
[14:49:11][C][wifi:408]: Local MAC: C0:49:EF:6B:EA:68
[14:49:11][C][wifi:413]: SSID: [redacted]
[14:49:11][C][wifi:416]: IP Address: 192.168.1.39
[14:49:11][C][wifi:420]: BSSID: [redacted]
[14:49:11][C][wifi:421]: Hostname: 'garage_door_opener'
[14:49:11][C][wifi:423]: Signal strength: -59 dB ▂▄▆█
[14:49:11][C][wifi:427]: Channel: 6
[14:49:11][C][wifi:428]: Subnet: 255.255.255.0
[14:49:11][C][wifi:429]: Gateway: 192.168.1.1
[14:49:11][C][wifi:430]: DNS1: 1.1.1.1
[14:49:11][C][wifi:431]: DNS2: 8.8.8.8
[14:49:11][C][logger:166]: Logger:
[14:49:11][C][logger:167]: Level: DEBUG
[14:49:11][C][logger:169]: Log Baud Rate: 115200
[14:49:11][C][logger:170]: Hardware UART: UART0
[14:49:11][C][switch.gpio:068]: GPIO Switch 'garage_door_button'
[14:49:11][C][switch.gpio:091]: Restore Mode: always OFF
[14:49:11][C][switch.gpio:031]: Pin: GPIO22
[14:49:11][C][mdns:115]: mDNS:
[14:49:11][C][mdns:116]: Hostname: garage_door_opener
[14:49:11][C][api:139]: API Server:
[14:49:11][C][api:140]: Address: garage_door_opener.local:6053
[14:49:11][C][api:144]: Using noise encryption: NO
I basically need to power on a pin on my ESP32 board for 3 seconds, to activate my garage door remote, thats it, but the switch entity is not begin detected.
Note there is a better way to do this. Delete the switch and script and use a button instead.
output:
- platform: gpio # Internal to the ESP
pin: 22
button:
- platform: output # Shared with HA.
output: garage_door_button
duration: 3s # does it really need to be pressed this long?
But now I am seeing with the button solution, that pin 22 or “D22” on the board is powered on, not doing anything when I press the button, it should only be powered on if someone presses the button in HA, and also then for 3 seconds.
internal (Optional, boolean): Mark this component as internal. Internal components will not be exposed to the frontend (like Home Assistant). Only specifying an id without a name will implicitly set this to true.
It applies to all & any components, so far I know.
I am currently making a system where I can control my old garage door system, by doing some soldering on my remote and the ESP32 board, and I have got it working so if I power pin 22 on my remote, the door opens.
I am seeing, that pin 22 or “D22” on the board is powered on, not doing anything when I press the button, even tough it should be only powered when the button is pressed and also then for 2 seconds.
INFO Successfully connected to garage_door_opener @ 192.168.1.39 in 0.092s
INFO Successful handshake with garage_door_opener @ 192.168.1.39 in 0.016s
[16:43:09][I][app:100]: ESPHome version 2024.4.0 compiled on Apr 22 2024, 16:38:17
[16:43:09][C][wifi:580]: WiFi:
[16:43:09][C][wifi:408]: Local MAC: C0:49:EF:6B:EA:68
[16:43:09][C][wifi:413]: SSID: [redacted]
[16:43:09][C][wifi:416]: IP Address: 192.168.1.39
[16:43:09][C][wifi:420]: BSSID: [redacted]
[16:43:09][C][wifi:421]: Hostname: 'garage_door_opener'
[16:43:09][C][wifi:423]: Signal strength: -42 dB ▂▄▆█
[16:43:09][C][wifi:427]: Channel: 6
[16:43:09][C][wifi:428]: Subnet: 255.255.255.0
[16:43:09][C][wifi:429]: Gateway: 192.168.1.1
[16:43:09][C][wifi:430]: DNS1: 1.1.1.1
[16:43:09][C][wifi:431]: DNS2: 8.8.8.8
[16:43:09][C][logger:166]: Logger:
[16:43:09][C][logger:167]: Level: DEBUG
[16:43:09][C][logger:169]: Log Baud Rate: 115200
[16:43:09][C][gpio.output:010]: GPIO Binary Output:
[16:43:09][C][gpio.output:011]: Pin: GPIO22
[16:43:09][C][output.button:010]: Output Button 'Gate'
[16:43:09][C][output.button:011]: Duration: 3.0s
[16:43:09][C][mdns:115]: mDNS:
[16:43:09][C][mdns:116]: Hostname: garage_door_opener
[16:43:09][C][api:139]: API Server:
[16:43:09][C][api:140]: Address: garage_door_opener.local:6053
[16:43:09][C][api:144]: Using noise encryption: NO
You mean pin 22 always providing power (state on) after board is powered on ?
Would be nice to have debug output to see styte changes of button & output.
