ESPHOME switch template unexpected off
604 / 5000
Risultati della traduzione
Hi everyone I have a problem that I have been trying to solve for a while and understand where I am wrong but without solution I have an ESP32 programmed with ESPHOME.
On it I have a dallas temperature sensor that opens a vasistas window more or less depending on the temperature. I’m trying to create a switch for the “Manual” command if turned on, the script with the function of opening or closing does not work.
Everything works except the simple “virtual” switch my template switch is this
switch:
#------------------- VASISTAS MANUALE -----------
    disabled_by_default: false
    optimistic: false
    assumed_state: false
    restore_state: true
in HA, once turned on, it switches off automatically after about 1 sec and an off message does not appear in the log:
switch activation
[21:53:25][D][switch:021]: 'Vasistas Manuale' Turning ON.
unexpected switch deactivation without exit log
Shouldn’t this be:
restore_state: yes
“yes” is equal to “true” indifferent, but I tested by term
without having a solution
Hi, did you find the issue or solution? Thanks
forget it, this was my issue
optimistic: true
Hi, yes I found how to make it work, I’ve been using it for a long time and it’s ultra stable.
The bug is found in the publication of the change of state which, unlike other buttons etc in the case of the switch, is published at the end, but in our case it does not allow maintaining the position.
I fixed it by posting manually right away
    turn_on_action:
      - switch.template.publish:
          state: ON
      - cover.stop: cover_vasistas
    turn_off_action:
          state: OFF
    icon: "mdi:gesture-swipe"
    optimistic: false
