Hello All,
I am try to figure out why my nodes sometimes miss the updates.
Seen on the picture that the brown one did not update it’s value until 3 hours.
I am using 6 nodes:
Same codes (Of Course the names, ips, sensor addresses are different.
esphome:
platform: ESP8266
board: esp01_1m
logger:
api:
ota:
password: "51400f11298538deac2ed1ec6b97db5a"
wifi:
ssid: "Telekom-84d7b5-2.4GHz"
password: "KJZJRDZQGZ3C"
ap:
ssid: "Node-02 Fallback Hotspot"
password: "jIE3nSyCpPoo"
fast_connect: true
manual_ip:
static_ip: 192.168.0.111
gateway: 192.168.0.1
subnet: 255.255.255.0
captive_portal:
deep_sleep:
run_duration: 60s
sleep_duration: 5min
dallas:
- pin: GPIO0
update_interval: 10s
- platform: dallas
address: 0xE03C01D075E47D28
accuracy_decimals: 1
filters:
- min:
window_size: 7
send_every: 4
send_first_at: 2
If I am checking the logs via serial debugger, the nodes working properly. (Wake up, connect to hass, send data, go back to sleep.)
How can I figure out why the updates in a day is so hectic? I assume that sometimes they can not connect to wifi but no idea how can I debug it!
Any idea is welcomed!
