Esphome template switch restore state not working
I have two template switches with the following configuration.
   restore_state: true
   optimistic: yes
   optimistic: yes
   restore_state: yes
I want them to restore the state after restarting. It was working fine till yesterday but now it is not restoring its state. What could be the problem. I am using Esp01s modules with this.
I have the same problem - did you find a solution? I’ll do a working around defining a number where the last switch state is stored, if no solutiom is possible
I couldn’t find a solution so i shifted to tasmota where the option to restore state worked.
You don’t have a turn_on or turn_off action defined. Therefore the state can not be restored.
I found the solution: Restore_state doesn’t work, even with turn_off /turn_on action. Waht works is “restore_mode: RESTORE_DEFAULT_OFF” - which is same with the GPIO-switches
Thanks for reporting back. I was wondering that, and even checked the template switch documentation before replying. I’ll submit a documentation edit.
perfect, thank you! That will help others a lot
Did you use restore_state: at all?
I’m wondering if it needs both, restore_state and restore_mode.
yes it needs both. without restore_state: true it doesn’t work, I just tested it
Ah damn. I had better remove my edit then.
I’m running in to this issue also.
Now restore_state is removed from template switch so all I can use is restore_mode and that does not do the job.
switch:
    name: "Person sensor on/off"
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
I need a boolean toggle that keeps the value past a reboot.
Switch Component — ESPHome
RESTORE_DEFAULT_ON - Attempt to restore state and default to ON.
I get that it might not be able to restore, but in that case it should be on, but after unplugging the ESP and plugging it back in the switch is off.
I have the same issue.
    name: Timing Buzzer enable
    optimistic: True
The state does not restore on restart.
I tried adding restore_state: True, but get this error.
  The restore_state option has been removed in 2023.7.0. Use the restore_mode option instead.
Is there any other way to restore the state of a template switch?
I could manage with a template binary sensor if there was a way to achieve the same but I’ve not found one.
I can use a spare GPIO but that’s not a very neat work-around.
Any suggestions?
