binary_sensor:
- platform: gpio
pin:
number: GPIO25
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
am trying to use touch buttons as light switch but they only workrs than i set than binary sensors in esp home. but they flickering on then i touch off then i remove my finger how to configure then to only switch on then touch second time i touch it turns off ?
Have you tried momentary switch in esphome ?
Yes, doesnât register than i use as momentary switch for some reason
tom_l
November 21, 2019, 9:53am
4
This is not a touch sensor:
platform: gpio
This is:
platform: esp32_touch
See documentation here:
You can use a home assistant automation and the the light.toggle service to change the light to itâs opposite state when a touch is detected
platform: state
entity_id: binary_sensor.touch_sensor
to: on
service: light.toggle
entity_id: light.your_light_here
Or you can automate it on the ESP without home assistant too:
binary_sensor:
- platform: esp32_touch
pin: GPIO27
threshold: 1000
on_press:
then:
- light.toggle: your_light_here
i ment button like this sorry i written stuff incorrectly
switch:
- platform: gpio
pin: D1
name: "Living Room Dehumidifier"
binary_sensor:
- platform: gpio
pin: D2
name: "Living Room Dehumidifier Toggle Button"
on_press:
then:
- switch.toggle: dehumidifier1
Found answer on another forum dunno why didnât find it sooner but thanks for help !
binary_sensor:
- platform: gpio
pin: GPIO13
name: "Kitchen LED TOUCH"
device_class: motion
on_press:
then:
- switch.toggle: relay1
switch:
- platform: gpio
pin: GPIO14
inverted: True
restore_mode: RESTORE_DEFAULT_OFF
