ESPHome Treatlife DS01C Dimmer - Multi Press Support
Has anyone using a Treatlife DS01C Dimmer been successful in getting on_multi_click to function? I’m not having any success and I am fearful that there is a hardware limitation that is preventing this.
device link: Treatlife DS01C Dimmer
substitutions:
  device_description: Treatlife DS01C Dimmer - Beken 1.1.17
  device_name: dimmer-wd05
  device_friendly_name: Dimmer WD05
## Hopefully you do not NEED to edit below this line
## Be sure you have a secrets.yaml file with the following entries:
## wifi_ssid: "my2g-wifi-name"
## wifi_password: "my2g-wifi-password"
## wifi_ap_password: "ap-password"
# Esphome core information
esphome:
  friendly_name: $device_friendly_name
  comment: $device_description
# The board type for this device
bk72xx:
  board: generic-bk7231t-qfn32-tuya
# Automatically logs all log messages, By default, all logs with a severity DEBUG or higher will be shown
# Increasing the log level severity (to e.g INFO or WARNING) can help with the performance of the application and memory size.
logger:
  level: VERBOSE
  baud_rate: 0
# Creata a simple web server on the node that can be accessed through any browser and a simple REST API
web_server:
# Make the node announce itself on the local network using the multicast DNS (MDNS)
mdns:
# ESPHome native API is used to communicate with clients directly, required for Home Assistant functionality
api:
# Permit OTA (Over The Air) updates
ota:
# Setup the wifi connection, and configure a possible local access point
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: $device_name
    password: !secret wifi_ap_password
# After 1 minute of unsuccessful WiFi connection attempts, the ESP will start a WiFi hotspot (with the credentials from ap configuration above)
captive_portal:
# Report the WiFi Signal strength
  - platform: wifi_signal
    update_interval: 60s
    filters:
      - delta: 0.01
      - throttle: 300s
# Provide buttons to restart device in normal and Safe modes.
button:
  - platform: restart
  - platform: safe_mode
    name: "Restart (Safe Mode)"
# Report LibreTiny Version Information
text_sensor:
  - platform: libretiny
    version:
# Confugure the UART for this device
# This is required to use the tuya component below https://bit.ly/3RdZuiM
uart:
  rx_pin: RX1
  tx_pin: TX1
  baud_rate: 9600
# Register the Tuya MCU connection
tuya:
# Configure the tuya dimmer https://bit.ly/46oyqle
light:
  - platform: "tuya"
    switch_datapoint: 1
    dimmer_datapoint: 2
    min_value_datapoint: 3
    min_value: 100
    max_value: 1000
binary_sensor:
  - platform: "tuya"
    sensor_datapoint: 1
    on_multi_click:
    - timing:
        - ON for at most 1s
        - OFF for at most 1s
        - ON for 0.5s to 1s
        - OFF for at least 0.2s
      then:
        - logger.log: "~~~~~~~~~~~~~~~~~~~~~~~ Double-Clicked"
Have you tried using on_double_click:? Slightly easier to configure (and execute).
I’m not sure that would work since it’s using tuya mcu
I did try this - I tried all the binary_sensor events - only press and state seem to work.
I agree, it only seems to trigger a press/click when the internal relay flips. I do not think I can use multi-press with this device.
Can you recommend a good dimmer compatible with ESPHome that supports this?
There’s martin jerry dimmer
Thank you for posting your code. I have about 90 of these dimmers working on Tasmota, but I could not figure out how to get them switched over to ESPhome. Spent 2 days on this and all I had to do was search for your code, thank you for post it!
