ESPHome trigger automation after restart
Hello everybody,
I have and esphome with this:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO32
      mode: INPUT_PULLUP
      inverted: False
  - platform: gpio
    pin:
      number: GPIO33
      mode: INPUT_PULLUP
      inverted: False
And an automation on HA like this:
alias: Toggle luce ingresso1
description: ""
  - type: turned_on
    platform: device
    device_id: 2081ba6b59d7ef7e067a1535cb2cc120
    entity_id: binary_sensor.ingresso1
    domain: binary_sensor
  - type: turned_off
    platform: device
  - type: turned_on
    platform: device
    device_id: 55eda31c2c13273b5d67df85e9ccdde3
    entity_id: binary_sensor.ingresso1_2
  - type: turned_off
    platform: device
condition: []
  - type: toggle
    device_id: 15752ce8270ff436092087ed22486dda
    entity_id: switch.ingresso1
    domain: switch
mode: restart
I don’t understand why after e restart of esp the trigger is triggered by esp.binary_sensor,
Someone have any idea?
Because the binary sensor state changed from unavailable to on or off which then triggers your automation :bulb:
You can actually just look at the binary sensor history to see that :sunglasses:
Quick fix might just to use something like:
    to: 'on'
and vice-versa in your automation :rocket:
Thank you, for the suggestion about logbook
The sequence is:
beginning:
Ingresso1 turned off
esp restart:
Ingresso1 became unavailable
esp come online:
Triggered:
Toggle luce ingresso1 triggered by state of Ingresso1 turned off
The issue is in the automation:
  - type: toggle
    domain: switch
The issue is in your triggers, not your action. I don’t like the unnecessarily-complicated device trigger syntax you’re using (from the UI, I assume), so to implement @orange-assistant’s suggestion above, I’d use:
  - platform: state
    to: 'on'
…and similarly for the other sensors. This will not react to changes from unavailable to on.
I can’t do that…
im stupid and i called for 3 esphome that control the light of ingresso the same name… so i need to specify the device id
i’ll change the name in all 3 esp…
Now itis working correctly, thank you @Troon
alias: Ingresso1 state change
description: ""
  - platform: state
    entity_id:
      - binary_sensor.cameras_ingresso1
      - binary_sensor.cucina_ingresso1
      - binary_sensor.studio_ingresso1
    to: "off"
  - platform: state
    entity_id:
    to: "on"
condition: []
  - type: toggle
    domain: switch
mode: single
