ESPHome Trigger if Wifi disconnects
I want to control water valves with relays on a Wmos mini with Esphome. Therefore, its important to ensure that the waterflow definitely stops if e.g. the Wifi connection to the home assistant breaks down. How can I implement something like
In my esp.yaml
switch:
  - platform: gpio
    pin: GPIO13   #D0
  - platform: gpio
    pin: GPIO12  #D6
  - platform: gpio
    pin: GPIO14  #D5
  - platform: gpio
    pin: GPIO16  #D5
use condition:
      if:
        condition:
          wifi.connected:
            then:
or if you want to check it HA is connected:
          - if:
              condition:
                api.connected:
              then:
I saw this condition, but I want to trigger if wifi.disconnected. Is something like !wifi.connected possible?
You can probably use something like this:
interval:
  - interval: 1min
    then:
      if:
        condition:
          not:
            wifi.connected:
        then:
I have implemented wifi connect and disconnect events at https://github.com/esphome/esphome/pull/3639
