ESPHome troubles with entity IDs
I have just made some chages to my config, completely unrelated to ESPHome.
Restarted hassio and it indeed restarts, but with the below errors in the log.
And that particular esphome device is unavailable (although the ESPHome dashboard shows it as online) and does not ‘work’…(A sonoff basic powering some dumb lights)
I have looked in /config/.storage/core.config_entries and do not see any duplicates anywhere.
Now, something i did do to this device a while back…
Originally i flashed it named as something else “sonoff_basic_01” whilst testing and ‘learning’ esphome.
Then once id decided on its use, reflased OTA changing the name, although esphome dash reports . Full path: /config/esphome/sonoff_basic_01.yaml device is now named "sonoff_kitchen_cupboard_lights "
Any tips or help as to where to look would be great
hassio log
2020-04-15 13:04:39 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 425, in _async_add_entity
      raise HomeAssistantError(msg)
      homeassistant.exceptions.HomeAssistantError: Entity id already exists: binary_sensor.sonoff_kitchen_cupboard_lights. Platform esphome does not generate unique IDs
            homeassistant.exceptions.HomeAssistantError: Entity id already exists: switch.sonoff_kitchen_cupboard_lights. Platform esphome does not generate unique IDs
                  homeassistant.exceptions.HomeAssistantError: Entity id already exists: sensor.sonoff_kitchen_cupboard_lights_signal. Platform esphome does not generate unique IDs
                        homeassistant.exceptions.HomeAssistantError: Entity id already exists: sensor.sonoff_kitchen_cupboard_lights_uptime. Platform esphome does not generate unique IDs
This can be disregarded, I removed the old integration and all seems to work ok.
Only question now is how to rename the yaml file associated with the device?
I may start another thread in this matter.
