Hi…
The below code i have cofigured for 3 Pzeam004t sensor in esphome but it showing error AssertionError,
so please anybody help, how to automate to torn on and off whenever the voltage value of L1, L2, L3 above 250 and below 180 relay will on(i.e RKV, YKV & BKV) otherwise will be off with ondelay of 5sec.
Thank you for your Help…
My present code:
esphome:
friendly_name: APS_PCB
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "CLPMWNBG8xQ8VS7KAM1Zm2ipN9IJZbkkUE1JuT3bso8="
ota:
password: "8c65f36d76c269c42ed8b45dfc64a28f"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Aps-Pcb Fallback Hotspot"
password: "qmT5EFIS68jD"
captive_portal:
uart:
tx_pin: 17
rx_pin: 16
baud_rate: 9600
data_bits: 8
stop_bits: 1
parity: NONE
modbus:
- id: mod_bus_pzem
send_wait_time: 250ms
- platform: pzemac
voltage:
address: 0x10
modbus_id: mod_bus_pzem
- platform: pzemac
voltage:
address: 0x11
- platform: pzemac
voltage:
address: 0x12
output:
- platform: gpio
pin: 18
- platform: gpio
pin: 19
- platform: gpio
pin: 23
on_value_range:
- above: 260
- below: 180
sensor.pzem_1.voltage:
then:
output.RVK.turn_on
after: 5s
sensor.pzem_2.voltage:
then:
output.YVK.turn_on
after: 5s
sensor.pzem_3.voltage:
then:
output.BVK.turn_on
after: 5s
Error Display:
Error log as text:
INFO ESPHome 2023.6.3
INFO Reading configuration /config/esphome/aps-pcb.yaml...
ERROR Unexpected exception while reading configuration:
File "/usr/local/bin/esphome", line 33, in <module>
sys.exit(load_entry_point('esphome', 'console_scripts', 'esphome')())
File "/esphome/esphome/__main__.py", line 1015, in main
return run_esphome(sys.argv)
File "/esphome/esphome/__main__.py", line 993, in run_esphome
config = read_config(dict(args.substitution) if args.substitution else {})
File "/esphome/esphome/config.py", line 986, in read_config
res = load_config(command_line_substitutions)
File "/esphome/esphome/config.py", line 840, in load_config
return _load_config(command_line_substitutions)
File "/esphome/esphome/config.py", line 828, in _load_config
result = validate_config(config, command_line_substitutions)
File "/esphome/esphome/config.py", line 756, in validate_config
result.run_validation_steps()
File "/esphome/esphome/config.py", line 125, in run_validation_steps
task.step.run(self)
File "/esphome/esphome/config.py", line 300, in run
component = get_component(self.domain)
File "/esphome/esphome/loader.py", line 180, in get_component
assert "." not in domain
AssertionError
