ESPHome - Unexpected error: ESP Chip Auto-Detection failed
I’ve flashed a few devices in the past with no problems but today I am getting this error when using
esphomeflasher.
Using 'COM8' as serial port.
Connecting........_____....._____....._____....._____....._____....._____....._____
Unexpected error: ESP Chip Auto-Detection failed: Failed to connect to Espressif device: Timed out waiting for packet header
It’s a simple config, just to get it on-line.
Can anyone help please?
substitutions:
  board: mhetesp32devkit
  device_name: esp32_01
  friendly_name: Garden Irrigation Controller
esphome:
  platform: ESP32
  board: ${board}
wifi:
  ssid: !secret wifi_ssid
  fast_connect: True
  ap:
    ssid: "Garden Irrigation Controller"
    password: "xxxxxxxxxxxx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
# Sensors
text_sensor:
  # ESPHome Version
  - platform: version
    name: ${friendly_name} ESPHome Version
  # Uptime
  - platform: uptime
  # WiFi Signal
  - platform: wifi_signal
    name: ${friendly_name} WiFi Signal
    update_interval: 60s
# Switches
switch:
  # Reboot
  - platform: restart
I found it.
Sometimes you need to hold down the Boot button on the ESP32 until it starts flashing.
i have same problem but i am using ESP8266 12-E so I didn’t find any answer cancan someone help to me ??? :(:(:(:frowning:
Nice one thanks!
me too… been going crazy trying to flash some esphome code on it. I’m using a nodemcu esp-12e chip. Either it’s busted or I’m surely not doing something right.
I ran into the same issue today " ESP Chip Auto-Detection failed". Solved it by hitting “Flash ESP” from ESP Flasher 3.1.0 within the first five seconds after powering up the Sonoff Bridge Pro.
