My script running on an ESP32 is running fine and sets the fan speed when a certain temperature is reached. Unfortunately it will not update the entity in Home Assistant so the dashboard is out of sync with the state of the ESP.
See my code below and the remark: Publish not working. When I uncomment it the following error occurs: 109:29: error: ‘class esphome::esp32_dac::ESP32DAC’ has no member named ‘publish_state’
id(dac_output_fans).publish_state(0.25);
Any tips on how to sync the values from the lambda code back into Home Assistant?
My code
esphome:
on_boot:
priority: -100 #lowest priority so start last
then:
- lambda: id(dac_output_fans).turn_off(); #turn off the fan at boot time
esp32:
board: esp32doit-devkit-v1
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "c659c88218892afdcfbbf393b0457bd9"
wifi:
ssid: !secret wifi_ssid
captive_portal:
#Use the DAC to control the fan via DAC GPIO25 or DAC GPIO26
#https://esphome.io/components/output/esp32_dac.html?highlight=dac
output:
- platform: esp32_dac
pin: GPIO25
#https://esphome.io/components/fan/speed.html
- platform: ledc
pin: GPIO26
frequency: 1000 Hz
fan:
- platform: speed
output: dac_output_fans
name: "Radiator huiskamer voor - Fan"
#https://esphome.io/components/sensor/dallas.html?highlight=dallas
#Get the temperature via the Dallas temp sensor
dallas:
- pin: GPIO32
#https://esphome.io/components/sensor/pulse_counter.html
#Get the RPM of one fan
- platform: pulse_counter
pin: GPIO27
name: "Radiator huiskamer voor - RPM"
update_interval: 10s
unit_of_measurement: 'RPM'
filters:
- multiply: 0.5 #fan runs according to specs 3500rpm, so need to convert the received pulses as that was max 8000
- platform: dallas
address: 0x980317331815ff28 #at first boot disable this code to retrieve the address and adjust it
name: "Radiator huiskamer voor - Temperature"
light:
- platform: monochromatic
output: pwm_output_leds
name: "Radiator huiskamer LEDs"
#Get value from Helper in Home Assistant
#https://esphome.io/components/binary_sensor/homeassistant.html
binary_sensor:
- platform: homeassistant
entity_id: input_boolean.radiator_huiskamer_voor_override
#logic:
time:
on_time:
- seconds: /10 # needs to be set, otherwise every second this is triggered!
minutes: '*' # Trigger every 0.5 minute
then:
lambda: !lambda |-
auto time = id(homeassistant_time).now();
int t_now = parse_number<int>(id(homeassistant_time).now().strftime("%H%M")).value();
float temp_measured = static_cast<int>(id(th12_temp).state);
if (id(override_from_home_assistant_helper).state)
//Do nothing as the override is active which is set in Home Assistant
else
if ((temp_measured) >= 28)
id(dac_output_fans).set_level(0.27); //set the speed level between 0 and 1 https://esphome.io/components/output/index.html
return id(dac_output_fans).state(0.27); publish not working
else
if (((temp_measured) >=25) && ((temp_measured) < 27))
id(dac_output_fans).set_level(0.25);
//id(dac_output_fans).publish_state(0.25); publish not working
else
if ((temp_measured) <= 24)
//id(dac_output_fans).publish_state(0);
