ESPHome update_interval performs interval before lambda function
Hey,
I’m new to ESPHome, and have to say thus far it has been great experience, quick and easy setup with simple interfacing to hassio; however I’m now facing and issue which I do not know how to resolve.
I have the below code which is configured to control a smart light strip, with a specific lambda function, where I want a change delayed every 6min.
  • platform: fastled_clockless
    chipset: WS2813
    pin: GPIO0
    num_leds: 40
    rgb_order: BRG
    effects:
    • addressable_lambda:
      name: “Self Test Effect”
      update_interval: 360s
      lambda: |-
      ESP_LOGD(“statustest”, “code starts here”);
However when I first send through the command to run the particular effect, it is delay for 6min (or what ever I set the ‘update_interval’ to). I want the effect to start starlight away, and then re-run every 6min. Is there a known way to perform this function?
After some time, and a little more learning, I found that you can declare and use static variables in the lambda function that keep over each iteration.
As such my code now runs well following example:
         name: "Shelf Segments"
         update_interval: 500ms
         lambda: |-
          static int last_update;
          int update_time = 50; //how quickly to update in sseconds
          int red; int blue; int green;
          if((last_update + (update_time * 1000)) < millis()){
             <your code goes here>
