In ESPHome 1.14.3 and 1.15-dev I’m unable to upload via a USB port. What’s happened, or what am I doing wrong?
The upload terminates with the message below (this is in 1.14.3).
I’ve tried “chmod a+rw /dev/ttyUSB1” in the esphome docker and outside.
I’ve tried connecting my ESP32 to a CP2102 usb interface, both 3.3v and 5v, both ground pins.
I don’t know what else to try. (OTA upload works fine, so it’s something with the usb)
Serial port /dev/ttyUSB1
File "/usr/local/lib/python3.6/dist-packages/serial/serialposix.py", line 265, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
OSError: [Errno 5] Input/output error: '/dev/ttyUSB1'
File "/root/.platformio/packages/tool-esptoolpy/esptool.py", line 2959, in <module>
_main()
File "/root/.platformio/packages/tool-esptoolpy/esptool.py", line 2952, in _main
main()
File "/root/.platformio/packages/tool-esptoolpy/esptool.py", line 2652, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "/root/.platformio/packages/tool-esptoolpy/esptool.py", line 222, in init
self._port = serial.serial_for_url(port)
File "/usr/local/lib/python3.6/dist-packages/serial/init.py", line 88, in serial_for_url
instance.open()
File "/usr/local/lib/python3.6/dist-packages/serial/serialposix.py", line 268, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 5] could not open port /dev/ttyUSB1: [Errno 5] Input/output error: '/dev/ttyUSB1'
*** [upload] Error 1
