ESPHome use on a Adafruit Matrix Portal M4
I’ve tried to setup a Adafruit Matrix Portal M4 based 64x32 display using this ESP Wrapper: GitHub - TillFleisch/ESPHome-HUB75-MatrixDisplayWrapper: Custom ESPHome component which wraps the ESP32-HUB75-MatrixPanel-DMA library into a ESPHome display component.
But I can’t seem to connect to the Matrix Portal after compiling. Has anyone used a Cortex M4 based device successfully?
Error in the log:
ERROR Please try running esptool.py --before default_reset --after hard_reset --baud 115200 --port /dev/ttyACM1 --chip esp32 write_flash -z --flash_size detect 0x10000 /data/build/info-display/.pioenvs/info-display/firmware.bin 0x1000 /data/build/info-display/.pioenvs/info-display/bootloader.bin 0x8000 /data/build/info-display/.pioenvs/info-display/partitions.bin 0xe000 /data/cache/platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin locally.
code:
esphome:
friendly_name: info display
platformio_options:
lib_deps:
- SPI
- Wire
- Adafruit BusIO
- adafruit/Adafruit GFX Library
- GitHub - TillFleisch/ESP32-HUB75-MatrixPanel-DMA: An Adafruit GFX Compatible Library for the ESP32, ESP32-S2, ESP32-S3 to drive HUB75 LED matrix panels using DMA for high refresh rates. Supports panel chaining.
external_components:
  • source: github://TillFleisch/ESPHome-HUB75-MatrixDisplayWrapper@main
    esp32:
    board: esp32dev
    framework:
    type: arduino
Enable logging
logger:
Enable Home Assistant API
api:
encryption:
key: “”
ota:
password: “”
wifi:
ssid: !secret wifi_ssid
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Info-Display Fallback Hotspot”
password: “”
captive_portal:
I have had some success with changing the board to esp32-s3-devkitc-1
It flashes and shows up in home assistant. I only have brightness and power. I can not get anything to print on the display
I may have messed up the pin out. I’ll look into it more when I have time.
This yaml works for my matrix portal s3
esphome:
  friendly_name: Matrix Portal
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
  - source: github://TillFleisch/ESPHome-HUB75-MatrixDisplayWrapper@main
font:
  # gfonts://family[@weight]
  - file: "gfonts://Roboto"
display:
  - platform: hub75_matrix_display
    width: 64
    height: 32
    R1_pin: 42
    G1_pin: 41
    B1_pin: 40
    R2_pin: 38
    G2_pin: 39
    B2_pin: 37
    A_pin: 45
    B_pin: 36
    C_pin: 48
    D_pin: 35
    E_pin: 21
    LAT_pin: 47
    OE_pin: 14
    CLK_pin: 2
have you gotten this working? I have the same device and would like to see if I can get ESPhome working with it
I ended up not being able to get esphome to work with Adafruit’s Matrix Portal M4. I setup the Matirix Portal to receive messages over MQTT instead. I used the Arduino IDE in the Matrix Portal. Works, but on occasion the Matrix Portal stop receiving MQTT messages has to be rebooted.
this config is really working for you?
I have the Same S3 Matrix Portal with an HUB75 Matrix and I simply cant get it to work. Through I have an 32x16 portal but this really should not make things more difficult …
esphome:
substitutions:
  xscrollpadding: "5" # in pix
  scroll_speed: .09s
esp32:
  framework:
    type: arduino
interval:
  - interval: 0.1s
    then:
      lambda: |-
        id(partlycloudy).next_frame();
        id(cloudy).next_frame();
        id(fog).next_frame();
        id(windy).next_frame();
  - interval: 0.1s
    then:
      animation.next_frame: cloudy
font:
  - file: /config/esphome/fonts/MatrixChunky8X.ttf
    glyphs:  |
      ! "#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz°
  - file: "gfonts://Micro 5"
color:
  - id: teal
    hex: 00CED1
  - id: blue
    hex: 7B68EE
  - id: brown
    hex: D2691E
  - id: orange
    hex: FFA500
  - id: green
    hex: 008000
  - id: pink
    hex: FF69B4
  - id: purple
    hex: 9400D3
  - id: red
    hex: FF0000
  - id: yellow
    hex: FFFF00
display:
    width: 64
    height: 32
    R1_pin: 42
    G1_pin: 41
    B1_pin: 40
    R2_pin: 38
    G2_pin: 39
    B2_pin: 37
    A_pin: 45
    B_pin: 36
    C_pin: 48
    D_pin: 35
    E_pin: 21
    LAT_pin: 47
    OE_pin: 14
    CLK_pin: 2
    brightness: 64
    update_interval: 32ms
    lambda: |-
      if (id(weather).state == "sunny") {
      id(sunny).next_frame();
      it.image(2, 10, id(sunny), COLOR_ON, COLOR_OFF);
      if (id(weather).state == "lightning-rainy") {
      id(rainylight).next_frame();
      it.image(2, 10, id(rainylight), COLOR_ON, COLOR_OFF);
      if (id(weather).state == "rainy") {
      id(rainy).next_frame();
      it.image(2, 10, id(rainy), COLOR_ON, COLOR_OFF);
      if (id(weather).state == "partlycloudy") {
      it.image(2, 10, id(partlycloudy), COLOR_ON, COLOR_OFF);
      if (id(weather).state == "cloudy") {
      it.image(2, 10, id(cloudy), COLOR_ON, COLOR_OFF);
      if (id(weather).state == "clear-night") {
      id(clearnight).next_frame();
      it.image(2, 10, id(clearnight), COLOR_ON, COLOR_OFF);
      if (id(weather).state == "fog") {
      it.image(2, 10, id(fog), COLOR_ON, COLOR_OFF);
      if (id(weather).state == "windy") {
      it.image(2, 10, id(windy), COLOR_ON, COLOR_OFF);
      it.strftime(10, 0, id(mono), id(purple),"%b %d", id(homeassistant_time).now());
      it.strftime(37, 0, id(mono), id(orange), "%I:%M", id(homeassistant_time).now());
      if (id(outsidetemp).has_state()) {
        it.printf(14, 10, id(mono), id(pink), "%.1f°", id(outsidetemp).state);
      if (id(motion).state) {
        id(pacman).next_frame();
        it.image(0, -15, id(pacman), COLOR_ON, COLOR_OFF);
      } else {
      static int16_t xpos = it.get_width();
      const char * text = id(quote).state.c_str();
      int x_start, y_start;
      int width, height;
      it.get_text_bounds(0, 22, text, id(mono), TextAlign::TOP_LEFT, &x_start, &y_start, &width, &height);
      if(xpos < -1 * (width + $xscrollpadding)) {xpos = it.get_width();}
      if(width <= it.get_width()) {xpos = 0;}
      it.print(xpos, 22, id(mono), id(red), TextAlign::TOP_LEFT, text);
      xpos--;
switch:
    matrix_id: matrix
number:
    matrix_id: matrix
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxx"
ota:
  safe_mode: true
wifi:
  ap:
    ssid: "Esphome-Web-C76B40"
    password: "n5SZyllaF9nO"
captive_portal:
animation:
  - file: /config/www/gif/pac-man.gif
    resize: 64x64
    type: RGB565
  - file: /config/esphome/weather/sunny.gif
    resize: 10x10
    type: RGB565
  - file: /config/esphome/weather/cloudy.gif
    resize: 10x10
    type: RGB565
  - file: /config/esphome/weather/partlycloudy.gif
    resize: 10x10
    type: RGB565
  - file: /config/esphome/weather/clearnight.gif
    resize: 10x10
    type: RGB565
  - file: /config/esphome/weather/fog.gif
    resize: 10x10
    type: RGB565
  - file: /config/esphome/weather/windy.gif
    resize: 10x10
    type: RGB565
  - file: /config/esphome/weather/rainylightening.gif
    resize: 10x10
    type: RGB565
  - file: /config/esphome/weather/rainy.gif
    resize: 10x10
    type: RGB565
image:
  - file: mdi:television-classic
    resize: 20x20
binary_sensor:
  - platform: homeassistant
    entity_id: binary_sensor.driveway_motion_motion
time:
    timezone: America/Chicago
text_sensor:
    name: "Weather Forecast From Home Assistant"
    entity_id: weather.forecast_central_hub
    internal: true
    entity_id: input_text.led_matrix_text
    internal: true
    entity_id: sensor.daily_quote
    attribute: q
    internal: true
    attribute: a
    internal: true
    entity_id: sensor.outside_temp_temperature
    internal: true
Thats my entire setup. It works Im pulling a sensor for temp and a quote of the day.
Reviving an old thread, did you get all your images from online somewhere or your own creations?
I made the Gif’s in photoshop
Can you please share the Gif’s with us?
Can you please share the Gif’s with us? Thanks
