ESPhome validation causes python error
‘’‘Running HA on RPI4, been getting this error for several releases.
Not sure if it an HA or ESPhome problem.
INFO Reading configuration /config/esphome/esp32_cam2.yaml…
File “/usr/local/bin/esphome”, line 11, in
load_entry_point(‘esphome==1.15.0.dev0’, ‘console_scripts’, ‘esphome’)()
File “/usr/local/lib/python3.6/dist-packages/esphome/main.py”, line 557, in main
return run_esphome(sys.argv)
File “/usr/local/lib/python3.6/dist-packages/esphome/main.py”, line 535, in run_esphome
config = read_config()
File “/usr/local/lib/python3.6/dist-packages/esphome/config.py”, line 819, in read_config
res = load_config()
File “/usr/local/lib/python3.6/dist-packages/esphome/config.py”, line 679, in load_config
return _load_config()
File “/usr/local/lib/python3.6/dist-packages/esphome/config.py”, line 661, in _load_config
config = yaml_util.load_yaml(CORE.config_path)
Continues - 32K of messages
As you are using the dev version I suggest you post an issue on github.
Appreciate the reply.
Actually it happens regardless of version.
