ESPHome value
What do you get when you visit the unit ESPHome in homeassistant, I get this, but some value shows nothing, it’s right?
How are you in your conf. ESPHome. This is for Swedish electricity meters, with Slimmezer+.
What does HA show?
What does your log show?
HI,
this is the my logs on HA , logs vattenfall5.yaml
INFO Reading configuration /config/esphome/vattenfall5.yaml...
INFO Starting log output from 192.168.1.30 using esphome API
INFO Successfully connected to 192.168.1.30
[14:24:31][I][app:102]: ESPHome version 2022.2.6 compiled on Mar  5 2022, 20:46:01
[14:24:31][C][wifi:491]: WiFi:
[14:24:31][C][wifi:353]:   Local MAC: 44:17:93:2B:5C:2E
[14:24:31][C][wifi:354]:   SSID: 'NETGEAR7'[redacted]
[14:24:31][C][wifi:355]:   IP Address: 192.168.1.30
[14:24:31][C][wifi:356]:   BSSID: DC:EF:09:F0:03:68[redacted]
[14:24:31][C][wifi:358]:   Hostname: 'vattenfall5'
[14:24:31][C][wifi:360]:   Signal strength: -52 dB ▂▄▆█
[14:24:31][C][wifi:364]:   Channel: 4
[14:24:31][C][wifi:365]:   Subnet: 255.255.255.0
[14:24:31][C][wifi:366]:   Gateway: 192.168.1.1
[14:24:31][C][wifi:367]:   DNS1: 192.168.1.1
[14:24:31][C][wifi:368]:   DNS2: 0.0.0.0
[14:24:31][C][logger:233]: Logger:
[14:24:31][C][logger:234]:   Level: DEBUG
[14:24:31][C][logger:235]:   Log Baud Rate: 0
[14:24:31][C][logger:236]:   Hardware UART: UART0
[14:24:31][C][uart.arduino_esp8266:102]: UART Bus:
[14:24:31][C][uart.arduino_esp8266:104]:   RX Pin: GPIO13
[14:24:31][C][uart.arduino_esp8266:106]:   RX Buffer Size: 1700
[14:24:31][C][uart.arduino_esp8266:108]:   Baud Rate: 115200 baud
[14:24:31][C][uart.arduino_esp8266:109]:   Data Bits: 8
[14:24:31][C][uart.arduino_esp8266:110]:   Parity: NONE
[14:24:31][C][uart.arduino_esp8266:111]:   Stop bits: 1
[14:24:31][C][uart.arduino_esp8266:113]:   Using hardware serial interface.
[14:24:31][C][uptime.sensor:031]: Uptime Sensor 'vattenfall5 Uptime'
[14:24:31][C][uptime.sensor:031]:   State Class: 'total_increasing'
[14:24:31][C][uptime.sensor:031]:   Unit of Measurement: 's'
[14:24:31][C][uptime.sensor:031]:   Accuracy Decimals: 0
[14:24:31][C][uptime.sensor:031]:   Icon: 'mdi:timer-outline'
[14:24:31][C][dsmr:275]: DSMR:
[14:24:31][C][dsmr:276]:   Max telegram length: 1700
[14:24:31][C][dsmr:277]:   Receive timeout: 0.2s
[14:24:31][C][dsmr:286]:   energy_delivered_tariff1 'Energy Consumed Tariff 1'
[14:24:31][C][dsmr:286]:     Device Class: 'energy'
[14:24:31][C][dsmr:286]:     State Class: 'total_increasing'
[14:24:31][C][dsmr:286]:     Unit of Measurement: 'kWh'
[14:24:31][C][dsmr:286]:     Accuracy Decimals: 3
[14:24:31][C][dsmr:286]:   energy_delivered_tariff2 'Energy Consumed Tariff 2'
[14:24:31][C][dsmr:286]:   energy_returned_tariff1 'Energy Produced Tariff 1'
[14:24:31][C][dsmr:286]:   energy_returned_tariff2 'Energy Produced Tariff 2'
[14:24:31][C][dsmr:286]:   power_delivered 'Power Consumed'
[14:24:31][C][dsmr:286]:     Device Class: 'power'
[14:24:31][C][dsmr:286]:     State Class: 'measurement'
[14:24:31][C][dsmr:286]:     Unit of Measurement: 'kW'
[14:24:31][C][dsmr:286]:   power_returned 'Power Produced'
[14:24:31][C][dsmr:286]:     Unit of Measurement: 'A'
[14:24:31][C][dsmr:286]:     Accuracy Decimals: 1
[14:24:31][C][dsmr:286]:   power_delivered_l1 'Power Consumed Phase 1'
[14:24:31][C][dsmr:286]:   power_delivered_l2 'Power Consumed Phase 2'
[14:24:31][C][dsmr:286]:   power_delivered_l3 'Power Consumed Phase 3'
[14:24:31][C][captive_portal:144]: Captive Portal:
[14:24:31][C][web_server:179]: Web Server:
[14:24:31][C][web_server:180]:   Address: 192.168.1.30:80
[14:24:32][C][mdns:084]: mDNS:
[14:24:32][C][mdns:085]:   Hostname: vattenfall5
[14:24:32][C][ota:085]: Over-The-Air Updates:
[14:24:32][C][ota:086]:   Address: 192.168.1.30:8266
[14:24:32][C][ota:089]:   Using Password.
[14:24:32][C][api:138]: API Server:
[14:24:32][C][api:139]:   Address: 192.168.1.30:6053
[14:24:32][C][api:143]:   Using noise encryption: NO
[14:24:32][C][wifi_signal.sensor:009]: WiFi Signal 'vattenfall5 Wi-Fi Signal'
[14:24:32][C][wifi_signal.sensor:009]:   Device Class: 'signal_strength'
[14:24:32][C][wifi_signal.sensor:009]:   State Class: 'measurement'
[14:24:32][C][wifi_signal.sensor:009]:   Unit of Measurement: 'dBm'
[14:24:32][C][wifi_signal.sensor:009]:   Accuracy Decimals: 0
[14:24:32][C][wifi_info:009]: WifiInfo IPAddress 'SlimmeLezer IP Address'
[14:24:32][C][wifi_info:011]: WifiInfo SSID 'SlimmeLezer Wi-Fi SSID'
[14:24:32][C][wifi_info:012]: WifiInfo BSSID 'SlimmeLezer Wi-Fi BSSID'
[14:24:34][D][sensor:124]: 'Power Consumed': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:34][D][sensor:124]: 'Power Produced': Sending state 3.53400 kW with 3 decimals of accuracy
[14:24:34][D][sensor:124]: 'Voltage Phase 1': Sending state 234.60001 V with 1 decimals of accuracy
[14:24:34][D][sensor:124]: 'Voltage Phase 2': Sending state 234.10001 V with 1 decimals of accuracy
[14:24:34][D][sensor:124]: 'Voltage Phase 3': Sending state 235.89999 V with 1 decimals of accuracy
[14:24:34][D][sensor:124]: 'Current Phase 1': Sending state 3.30000 A with 1 decimals of accuracy
[14:24:34][D][sensor:124]: 'Current Phase 2': Sending state 5.20000 A with 1 decimals of accuracy
[14:24:34][D][sensor:124]: 'Current Phase 3': Sending state 6.70000 A with 1 decimals of accuracy
[14:24:34][D][sensor:124]: 'Power Consumed Phase 1': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:34][D][sensor:124]: 'Power Consumed Phase 2': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:34][D][sensor:124]: 'Power Consumed Phase 3': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:34][D][sensor:124]: 'Power Produced Phase 1': Sending state 0.77100 kW with 3 decimals of accuracy
[14:24:34][D][sensor:124]: 'Power Produced Phase 2': Sending state 1.19700 kW with 3 decimals of accuracy
[14:24:34][D][sensor:124]: 'Power Produced Phase 3': Sending state 1.56500 kW with 3 decimals of accuracy
[14:24:34][D][text_sensor:067]: 'DSMR Identification': Sending state 'AUX5U18SEH13F10024'
[14:24:38][D][sensor:124]: 'vattenfall5 Uptime': Sending state 91.34000 s with 0 decimals of accuracy
[14:24:39][D][sensor:124]: 'Power Consumed': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:39][D][sensor:124]: 'Power Produced': Sending state 3.52600 kW with 3 decimals of accuracy
[14:24:39][D][sensor:124]: 'Voltage Phase 1': Sending state 234.89999 V with 1 decimals of accuracy
[14:24:39][D][sensor:124]: 'Voltage Phase 2': Sending state 234.30000 V with 1 decimals of accuracy
[14:24:39][D][sensor:124]: 'Voltage Phase 3': Sending state 236.20000 V with 1 decimals of accuracy
[14:24:39][D][sensor:124]: 'Current Phase 1': Sending state 3.20000 A with 1 decimals of accuracy
[14:24:39][D][sensor:124]: 'Current Phase 2': Sending state 5.20000 A with 1 decimals of accuracy
[14:24:39][D][sensor:124]: 'Current Phase 3': Sending state 6.70000 A with 1 decimals of accuracy
[14:24:39][D][sensor:124]: 'Power Consumed Phase 1': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:39][D][sensor:124]: 'Power Consumed Phase 2': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:39][D][sensor:124]: 'Power Consumed Phase 3': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:39][D][sensor:124]: 'Power Produced Phase 1': Sending state 0.76800 kW with 3 decimals of accuracy
INFO 192.168.1.30: Error while reading incoming messages: Error while reading data: [Errno 104] Connection reset by peer
INFO Disconnected from ESPHome API for 192.168.1.30
WARNING Disconnected from API
INFO 192.168.1.30: Ping Failed: Error while reading data: [Errno 104] Connection reset by peer
[14:24:54][D][sensor:124]: 'Power Consumed': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:54][D][sensor:124]: 'Power Produced': Sending state 3.55700 kW with 3 decimals of accuracy
[14:24:54][D][sensor:124]: 'Voltage Phase 1': Sending state 234.80000 V with 1 decimals of accuracy
[14:24:54][D][sensor:124]: 'Voltage Phase 2': Sending state 233.80000 V with 1 decimals of accuracy
[14:24:54][D][sensor:124]: 'Voltage Phase 3': Sending state 235.89999 V with 1 decimals of accuracy
[14:24:54][D][sensor:124]: 'Current Phase 1': Sending state 3.30000 A with 1 decimals of accuracy
[14:24:54][D][sensor:124]: 'Current Phase 2': Sending state 5.30000 A with 1 decimals of accuracy
[14:24:54][D][sensor:124]: 'Current Phase 3': Sending state 6.70000 A with 1 decimals of accuracy
[14:24:54][D][sensor:124]: 'Power Consumed Phase 1': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:54][D][sensor:124]: 'Power Consumed Phase 2': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:54][D][sensor:124]: 'Power Consumed Phase 3': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:54][D][sensor:124]: 'Power Produced Phase 1': Sending state 0.77700 kW with 3 decimals of accuracy
[14:24:54][D][sensor:124]: 'Power Produced Phase 2': Sending state 1.20900 kW with 3 decimals of accuracy
[14:24:54][D][sensor:124]: 'Power Produced Phase 3': Sending state 1.56900 kW with 3 decimals of accuracy
[14:24:54][D][text_sensor:067]: 'DSMR Identification': Sending state 'AUX5U18SEH13F10024'
[14:24:59][D][sensor:124]: 'Power Consumed': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:59][D][sensor:124]: 'Power Produced': Sending state 3.55400 kW with 3 decimals of accuracy
[14:24:59][D][sensor:124]: 'Voltage Phase 1': Sending state 234.70000 V with 1 decimals of accuracy
[14:24:59][D][sensor:124]: 'Voltage Phase 2': Sending state 233.80000 V with 1 decimals of accuracy
[14:24:59][D][sensor:124]: 'Voltage Phase 3': Sending state 235.80000 V with 1 decimals of accuracy
[14:24:59][D][sensor:124]: 'Current Phase 1': Sending state 3.30000 A with 1 decimals of accuracy
[14:24:59][D][sensor:124]: 'Current Phase 2': Sending state 5.30000 A with 1 decimals of accuracy
[14:24:59][D][sensor:124]: 'Current Phase 3': Sending state 6.70000 A with 1 decimals of accuracy
[14:24:59][D][sensor:124]: 'Power Consumed Phase 1': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:59][D][sensor:124]: 'Power Consumed Phase 2': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:59][D][sensor:124]: 'Power Consumed Phase 3': Sending state 0.00000 kW with 3 decimals of accuracy
[14:24:59][D][sensor:124]: 'Power Produced Phase 1': Sending state 0.77700 kW with 3 decimals of accuracy
[14:24:59][D][sensor:124]: 'Power Produced Phase 2': Sending state 1.20700 kW with 3 decimals of accuracy
[14:24:59][D][sensor:124]: 'Power Produced Phase 3': Sending state 1.57000 kW with 3 decimals of accuracy
[14:24:59][D][text_sensor:067]: 'DSMR Identification': Sending state 'AUX5U18SEH13F10024'
[14:25:04][D][sensor:124]: 'Power Consumed': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:04][D][sensor:124]: 'Power Produced': Sending state 3.55600 kW with 3 decimals of accuracy
[14:25:04][D][sensor:124]: 'Voltage Phase 1': Sending state 234.80000 V with 1 decimals of accuracy
[14:25:04][D][sensor:124]: 'Voltage Phase 2': Sending state 234.00000 V with 1 decimals of accuracy
[14:25:04][D][sensor:124]: 'Voltage Phase 3': Sending state 236.20000 V with 1 decimals of accuracy
[14:25:04][D][sensor:124]: 'Current Phase 1': Sending state 3.30000 A with 1 decimals of accuracy
[14:25:04][D][sensor:124]: 'Current Phase 2': Sending state 5.30000 A with 1 decimals of accuracy
[14:25:04][D][sensor:124]: 'Current Phase 3': Sending state 6.70000 A with 1 decimals of accuracy
[14:25:04][D][sensor:124]: 'Power Consumed Phase 1': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:04][D][sensor:124]: 'Power Consumed Phase 2': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:04][D][sensor:124]: 'Power Consumed Phase 3': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:04][D][sensor:124]: 'Power Produced Phase 1': Sending state 0.77400 kW with 3 decimals of accuracy
[14:25:04][D][sensor:124]: 'Power Produced Phase 2': Sending state 1.21000 kW with 3 decimals of accuracy
[14:25:04][D][sensor:124]: 'Power Produced Phase 3': Sending state 1.57000 kW with 3 decimals of accuracy
[14:25:04][D][text_sensor:067]: 'DSMR Identification': Sending state 'AUX5U18SEH13F10024'
[14:25:09][D][sensor:124]: 'Power Consumed': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:09][D][sensor:124]: 'Power Produced': Sending state 2.36800 kW with 3 decimals of accuracy
[14:25:09][D][sensor:124]: 'Voltage Phase 1': Sending state 234.89999 V with 1 decimals of accuracy
[14:25:09][D][sensor:124]: 'Voltage Phase 2': Sending state 233.39999 V with 1 decimals of accuracy
[14:25:09][D][sensor:124]: 'Voltage Phase 3': Sending state 235.39999 V with 1 decimals of accuracy
[14:25:09][D][sensor:124]: 'Current Phase 1': Sending state 3.30000 A with 1 decimals of accuracy
[14:25:09][D][sensor:124]: 'Current Phase 2': Sending state 2.60000 A with 1 decimals of accuracy
[14:25:09][D][sensor:124]: 'Current Phase 3': Sending state 4.10000 A with 1 decimals of accuracy
[14:25:09][D][sensor:124]: 'Power Consumed Phase 1': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:09][D][sensor:124]: 'Power Consumed Phase 2': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:09][D][sensor:124]: 'Power Consumed Phase 3': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:09][D][sensor:124]: 'Power Produced Phase 1': Sending state 0.77900 kW with 3 decimals of accuracy
[14:25:09][D][sensor:124]: 'Power Produced Phase 2': Sending state 0.61600 kW with 3 decimals of accuracy
[14:25:09][D][sensor:124]: 'Power Produced Phase 3': Sending state 0.97200 kW with 3 decimals of accuracy
[14:25:09][D][text_sensor:067]: 'DSMR Identification': Sending state 'AUX5U18SEH13F10024'
[14:25:14][D][sensor:124]: 'Power Consumed': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:14][D][sensor:124]: 'Power Produced': Sending state 2.37900 kW with 3 decimals of accuracy
[14:25:14][D][sensor:124]: 'Voltage Phase 1': Sending state 234.50000 V with 1 decimals of accuracy
[14:25:14][D][sensor:124]: 'Voltage Phase 2': Sending state 233.00000 V with 1 decimals of accuracy
[14:25:14][D][sensor:124]: 'Voltage Phase 3': Sending state 235.00000 V with 1 decimals of accuracy
[14:25:14][D][sensor:124]: 'Current Phase 1': Sending state 3.30000 A with 1 decimals of accuracy
[14:25:14][D][sensor:124]: 'Current Phase 2': Sending state 2.70000 A with 1 decimals of accuracy
[14:25:14][D][sensor:124]: 'Current Phase 3': Sending state 4.10000 A with 1 decimals of accuracy
[14:25:14][D][sensor:124]: 'Power Consumed Phase 1': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:14][D][sensor:124]: 'Power Consumed Phase 2': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:14][D][sensor:124]: 'Power Consumed Phase 3': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:14][D][sensor:124]: 'Power Produced Phase 1': Sending state 0.78200 kW with 3 decimals of accuracy
[14:25:14][D][sensor:124]: 'Power Produced Phase 2': Sending state 0.62000 kW with 3 decimals of accuracy
[14:25:14][D][sensor:124]: 'Power Produced Phase 3': Sending state 0.97600 kW with 3 decimals of accuracy
[14:25:14][D][text_sensor:067]: 'DSMR Identification': Sending state 'AUX5U18SEH13F10024'
[14:25:19][D][sensor:124]: 'Power Consumed': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:19][D][sensor:124]: 'Power Produced': Sending state 2.37600 kW with 3 decimals of accuracy
[14:25:19][D][sensor:124]: 'Voltage Phase 1': Sending state 234.89999 V with 1 decimals of accuracy
[14:25:19][D][sensor:124]: 'Voltage Phase 2': Sending state 233.30000 V with 1 decimals of accuracy
[14:25:19][D][sensor:124]: 'Voltage Phase 3': Sending state 235.30000 V with 1 decimals of accuracy
[14:25:19][D][sensor:124]: 'Current Phase 1': Sending state 3.30000 A with 1 decimals of accuracy
[14:25:19][D][sensor:124]: 'Current Phase 2': Sending state 2.70000 A with 1 decimals of accuracy
[14:25:19][D][sensor:124]: 'Current Phase 3': Sending state 4.10000 A with 1 decimals of accuracy
[14:25:19][D][sensor:124]: 'Power Consumed Phase 1': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:19][D][sensor:124]: 'Power Consumed Phase 2': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:19][D][sensor:124]: 'Power Consumed Phase 3': Sending state 0.00000 kW with 3 decimals of accuracy
[14:25:19][D][sensor:124]: 'Power Produced Phase 1': Sending state 0.77900 kW with 3 decimals of accuracy
[14:25:19][D][sensor:124]: 'Power Produced Phase 2': Sending state 0.62100 kW with 3 decimals of accuracy
[14:25:19][D][sensor:124]: 'Power Produced Phase 3': Sending state 0.97500 kW with 3 decimals of accuracy
[14:25:19][D][text_sensor:067]: 'DSMR Identification': Sending state 'AUX5U18SEH13F10024'
[14:25:21][D][sensor:124]: 'vattenfall5 Wi-Fi Signal': Sending state -54.00000 dBm with 0 decimals of accuracy
