ESPHome Watchdog triggered with more than 100 gpios
Hello guys,
I made a board with 12 MCP23017 to add theoretically 12x16=192 gpio on the 2 I2C buses to my esp32.
But the esp32 is stuck in a boot loop when I add 50 outputs (switch) and 52 inputs (binary_sensor) so 102 additional gpio (and 12 covers).
It seems the watchdog timer limit is reached :
[11:31:42][I][app:062]: setup() finished successfully!
[11:31:42][D][esp32.preferences:114]: Saving preferences to flash...
[11:31:43]E (9958) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
[11:31:43]E (9958) task_wdt:  - loopTask (CPU 1)
[11:31:43]E (9958) task_wdt: Tasks currently running:
[11:31:43]E (9958) task_wdt: CPU 0: ipc0
[11:31:43]E (9958) task_wdt: CPU 1: IDLE
[11:31:43]E (9958) task_wdt: Aborting.
[11:31:43]
[11:31:43]abort() was called at PC 0x400fd3f8 on core 0
I tried to increase the i2c frequency from 100 to 200KHz but nothing changed.
I tried to unplung the i2c plug from my board to have a standalone esp32 : same problem.
Is there a trick to increase the watchdog or avoid this timeout ?
I spent so many hours on my project that I would be very gratful if someone could help me :slightly_smiling_face:
Thanks in advance
Did you try to decrease that number? Just to get at least an idea were around the “break point” is? It might be a combination of something :thinking: Like does it maybe already work if you comment out the covers for example?
Yes, 102 is already the "break point’, if I add a binary sensor or a switch it crashes.
But actually it’s not so easy, for example I have 102 gpios, it works, I add another one, it doesn’t work anymore, I comment the last one to come back as previously and it still doesn’t work, I have to remove more gpio… the limit is not 100% reproducible, the behavior is weird, I don’t understand what is the combination which triggers the watchdog.
I searched on Google, I don’t find this kind of problem, nobody had the same idea as me to command all the house with one ESP32… On theory it seems so easy :cry:
I could progess in my investigations and it’s interesting… but incomprehensible at my level :sweat_smile:
I rewrote the yaml with only the gpio declaration as baseline, no trigger, no automation, no name only the minimum : I could declare 192 gpios on the 2 I2C buses and it works !
After that, I copied my previous yaml litle by little, gpio by gpio until the watchdog error and I found what is the cause : it’s the id and/or name length !
Indeed, in my basic yaml, I only defined some basic id (in1, in2, in3… out1, out2…) without any name. If I rename the id and add a real name for example SWITCH_KITCHEN_1 or LIGHT_KITCHEN_1, with around a hundred gpios I face the watchdog error.
Can someone explain this behaviour ? Is there a workaround ? I don’t see any link between a watchdog timeout and id or name length :thinking:
Here is my basic yaml wich works
esphome:
esp32:
  board: esp32-poe
logger:
wifi:
  ssid: "****"
  password: "****"
  ap:
    ssid: "example"
    password: "****"
web_server:
  port: 80
  local: true
api:
ota:
i2c:
  - id: bus_a
    sda: GPIO05
    scl: GPIO03
    frequency: 400kHz
  - id: bus_b
    sda: GPIO15
    scl: GPIO16
    frequency: 400kHz
mcp23017:
  - id: 'mcp23017_hub_a1'
    i2c_id: bus_a
    address: 0x20
  - id: 'mcp23017_hub_a2'
    i2c_id: bus_a
    address: 0x21
  - id: 'mcp23017_hub_a3'
    i2c_id: bus_a
    address: 0x22
  - id: 'mcp23017_hub_a4'
    i2c_id: bus_a
    address: 0x24
  - id: 'mcp23017_hub_a5'
    i2c_id: bus_a
    address: 0x23
  - id: 'mcp23017_hub_a6'
    i2c_id: bus_a
    address: 0x25
  - id: 'mcp23017_hub_a7'
    i2c_id: bus_a
    address: 0x26
  - id: 'mcp23017_hub_a8'
    i2c_id: bus_a
    address: 0x27
  - id: 'mcp23017_hub_b1'
    i2c_id: bus_b
    address: 0x20
  - id: 'mcp23017_hub_b2'
    i2c_id: bus_b
    address: 0x21
  - id: 'mcp23017_hub_b3'
    i2c_id: bus_b
    address: 0x22
  - id: 'mcp23017_hub_b4'
    i2c_id: bus_b
    address: 0x23
switch:
  - platform: gpio
    pin:
      mcp23xxx: mcp23017_hub_a1
      number: 15
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      mcp23xxx: mcp23017_hub_a2
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 9
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 8
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      mcp23xxx: mcp23017_hub_a3
      number: 15
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      mcp23xxx: mcp23017_hub_a4
      number: 15
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 01
    pin:
      mcp23xxx: mcp23017_hub_a5
      number: 15
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 02
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 03
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 04
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 05
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 06
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 07
    pin:
      mcp23xxx: mcp23017_hub_a6
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 08
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 09
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 10
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 11
    pin:
      number: 9
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 12
    pin:
      number: 8
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 13
    pin:
      mcp23xxx: mcp23017_hub_a7
      number: 15
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 14
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 15
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 16
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 17
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 18
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 19
    pin:
      mcp23xxx: mcp23017_hub_a8
      number: 2
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 20
    pin:
      number: 3
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 21
    pin:
      number: 4
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 22
    pin:
      number: 5
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 23
    pin:
      number: 6
      mode: OUTPUT
      inverted: False
  - platform: gpio #out2 24
    pin:
      number: 7
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 01
    pin:
      mcp23xxx: mcp23017_hub_b1
      number: 8
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 02
    pin:
      number: 9
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 03
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 04
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 05
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 06
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 07
    pin:
      mcp23xxx: mcp23017_hub_b2
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 08
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 09
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 10
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 11
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 12
    pin:
      number: 15
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 13
    pin:
      mcp23xxx: mcp23017_hub_b3
      number: 0
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 14
    pin:
      number: 1
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 15
    pin:
      number: 2
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 16
    pin:
      number: 3
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 17
    pin:
      number: 4
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 18
    pin:
      number: 5
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 19
    pin:
      mcp23xxx: mcp23017_hub_b4
      number: 2
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 20
    pin:
      number: 3
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 21
    pin:
      number: 4
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 22
    pin:
      number: 5
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 23
    pin:
      number: 6
      mode: OUTPUT
      inverted: False
  - platform: gpio #out3 24
    pin:
      number: 7
      mode: OUTPUT
      inverted: False
binary_sensor:
  - platform: gpio
    pin:
      number: 7
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 4
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 3
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 2
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 9
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 8
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 15
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 14
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 7
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 4
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 3
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 2
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 7
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 23
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: True
    pin:
      number: 4
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 25
    pin:
      number: 3
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 26
    pin:
      number: 2
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 27
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 28
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 29
    pin:
      number: 9
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 30
    pin:
      number: 8
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 31
    pin:
      number: 9
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 32
    pin:
      number: 8
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 33
    pin:
      number: 7
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 34
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 35
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 36
    pin:
      number: 4
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 37
    pin:
      number: 3
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 38
    pin:
      number: 2
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 39
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in1 40
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 01
    pin:
      number: 7
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 02
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 03
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 04
    pin:
      number: 4
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 05
    pin:
      number: 3
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 06
    pin:
      number: 2
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 07
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 08
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 09
    pin:
      number: 9
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 10
    pin:
      number: 8
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 11
    pin:
      number: 15
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 12
    pin:
      number: 14
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 13
    pin:
      number: 7
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 14
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 15
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 16
    pin:
      number: 4
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 17
    pin:
      number: 3
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 18
    pin:
      number: 2
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 19
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 20
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 21
    pin:
      number: 7
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 22
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 23
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 24
    pin:
      number: 4
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 25
    pin:
      number: 3
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 26
    pin:
      number: 2
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 27
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 28
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 29
    pin:
      number: 9
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 30
    pin:
      number: 8
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 31
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 32
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 33
    pin:
      number: 15
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 34
    pin:
      number: 14
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 35
    pin:
      number: 13
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 36
    pin:
      number: 12
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 37
    pin:
      number: 11
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 38
    pin:
      number: 10
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 39
    pin:
      number: 9
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in2 40
    pin:
      number: 8
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 01
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 02
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 03
    pin:
      number: 2
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 04
    pin:
      number: 3
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 05
    pin:
      number: 4
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 06
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 07
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 08
    pin:
      number: 7
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 09
    pin:
      number: 14
      mode: INPUT_PULLUP
      inverted: True
    filters:
      - delayed_on: 3ms
  - platform: gpio #in3 10
    pin:
      number: 15
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 11
    pin:
      number: 8
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 12
    pin:
      number: 9
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 13
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 14
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 15
    pin:
      number: 2
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 16
    pin:
      number: 3
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 17
    pin:
      number: 4
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 18
    pin:
      number: 5
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 19
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 20
    pin:
      number: 7
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 21
    pin:
      number: 15
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 22
    pin:
      number: 14
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 23
    pin:
      number: 13
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 24
    pin:
      number: 12
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 25
    pin:
      number: 11
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 26
    pin:
      number: 10
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 27
    pin:
      number: 9
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 28
    pin:
      number: 8
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 29
    pin:
      number: 6
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 30
    pin:
      number: 7
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 31
    pin:
      number: 0
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 32
    pin:
      number: 1
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 33
    pin:
      number: 15
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 34
    pin:
      number: 14
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 35
    pin:
      number: 13
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 36
    pin:
      number: 12
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 37
    pin:
      number: 11
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 38
    pin:
      number: 10
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 39
    pin:
      number: 9
      mode: INPUT_PULLUP
      inverted: True
  - platform: gpio #in3 40
    pin:
      number: 8
      mode: INPUT_PULLUP
      inverted: True
Here is the same yaml with long id and names with watchdog error (1/2)
esphome:
esp32:
  board: esp32-poe
logger:
wifi:
  ssid: "****"
  password: "****"
  ap:
    ssid: "example"
    password: "****"
web_server:
  port: 80
  local: true
api:
ota:
i2c:
  - id: bus_a
    sda: GPIO05
    scl: GPIO03
    frequency: 400kHz
  - id: bus_b
    sda: GPIO15
    scl: GPIO16
    frequency: 400kHz
mcp23017:
    i2c_id: bus_a
    address: 0x20
    i2c_id: bus_a
    address: 0x21
    i2c_id: bus_a
    address: 0x22
    i2c_id: bus_a
    address: 0x24
    i2c_id: bus_a
    address: 0x23
    i2c_id: bus_a
    address: 0x25
    i2c_id: bus_a
    address: 0x26
    i2c_id: bus_a
    address: 0x27
    i2c_id: bus_b
    address: 0x20
    i2c_id: bus_b
    address: 0x21
    i2c_id: bus_b
    address: 0x22
    i2c_id: bus_b
    address: 0x23
switch:
  - platform: gpio
    pin:
      number: 15
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 9
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 8
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 15
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 15
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
  - platform: gpio
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
    pin:
      number: 15
      mode: OUTPUT
      inverted: False
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
    pin:
      number: 9
      mode: OUTPUT
      inverted: False
    pin:
      number: 8
      mode: OUTPUT
      inverted: False
    pin:
      number: 15
      mode: OUTPUT
      inverted: False
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
    pin:
      number: 2
      mode: OUTPUT
      inverted: False
    pin:
      number: 3
      mode: OUTPUT
      inverted: False
    pin:
      number: 4
      mode: OUTPUT
      inverted: False
    pin:
      number: 5
      mode: OUTPUT
      inverted: False
    pin:
      number: 6
      mode: OUTPUT
      inverted: False
    pin:
      number: 7
      mode: OUTPUT
      inverted: False
    pin:
      number: 8
      mode: OUTPUT
      inverted: False
    pin:
      number: 9
      mode: OUTPUT
      inverted: False
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
    pin:
      number: 10
      mode: OUTPUT
      inverted: False
    pin:
      number: 11
      mode: OUTPUT
      inverted: False
    pin:
      number: 12
      mode: OUTPUT
      inverted: False
    pin:
      number: 13
      mode: OUTPUT
      inverted: False
    pin:
      number: 14
      mode: OUTPUT
      inverted: False
    pin:
      number: 15
      mode: OUTPUT
      inverted: False
    pin:
      number: 0
      mode: OUTPUT
      inverted: False
    pin:
      number: 1
      mode: OUTPUT
      inverted: False
    pin:
      number: 2
      mode: OUTPUT
      inverted: False
    pin:
      number: 3
      mode: OUTPUT
      inverted: False
    pin:
      number: 4
      mode: OUTPUT
      inverted: False
    pin:
      number: 5
      mode: OUTPUT
      inverted: False
    pin:
      number: 2
      mode: OUTPUT
      inverted: False
    pin:
      number: 3
      mode: OUTPUT
      inverted: False
    pin:
      number: 4
      mode: OUTPUT
      inverted: False
    pin:
      number: 5
      mode: OUTPUT
      inverted: False
    pin:
      number: 6
      mode: OUTPUT
      inverted: False
    pin:
      number: 7
      mode: OUTPUT
      inverted: False
Here is the same yaml with long id and names with watchdog error (2/2)
binary_sensor:
  • platform: gpio
    pin:
    number: 7
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 6
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 5
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 4
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 3
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 2
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 9
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 8
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 15
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 14
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 7
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 6
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 5
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 4
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 3
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 2
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 7
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio
    pin:
    number: 6
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 23
    pin:
    number: 5
    mode: INPUT_PULLUP
    inverted: True
    pin:
    number: 4
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 25
    pin:
    number: 3
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 26
    pin:
    number: 2
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 27
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 28
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 29
    pin:
    number: 9
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 30
    pin:
    number: 8
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 31
    pin:
    number: 9
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 32
    pin:
    number: 8
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 33
    pin:
    number: 7
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 34
    pin:
    number: 6
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 35
    pin:
    number: 5
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 36
    pin:
    number: 4
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 37
    pin:
    number: 3
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 38
    pin:
    number: 2
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 39
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in1 40
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 01
    pin:
    number: 7
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 02
    pin:
    number: 6
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 03
    pin:
    number: 5
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 04
    pin:
    number: 4
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 05
    pin:
    number: 3
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 06
    pin:
    number: 2
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 07
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 08
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 09
    pin:
    number: 9
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 10
    pin:
    number: 8
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 11
    pin:
    number: 15
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 12
    pin:
    number: 14
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 13
    pin:
    number: 7
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 14
    pin:
    number: 6
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 15
    pin:
    number: 5
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 16
    pin:
    number: 4
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 17
    pin:
    number: 3
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 18
    pin:
    number: 2
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 19
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 20
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 21
    pin:
    number: 7
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 22
    pin:
    number: 6
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 23
    pin:
    number: 5
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 24
    pin:
    number: 4
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 25
    pin:
    number: 3
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 26
    pin:
    number: 2
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 27
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 28
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 29
    pin:
    number: 9
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 30
    pin:
    number: 8
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 31
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 32
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 33
    pin:
    number: 15
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 34
    pin:
    number: 14
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 35
    pin:
    number: 13
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 36
    pin:
    number: 12
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 37
    pin:
    number: 11
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 38
    pin:
    number: 10
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 39
    pin:
    number: 9
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in2 40
    pin:
    number: 8
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 01
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 02
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 03
    pin:
    number: 2
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 04
    pin:
    number: 3
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 05
    pin:
    number: 4
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 06
    pin:
    number: 5
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 07
    pin:
    number: 6
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 08
    pin:
    number: 7
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 09
    pin:
    number: 14
    mode: INPUT_PULLUP
    inverted: True
    filters:
    • delayed_on: 3ms
  • platform: gpio #in3 10
    pin:
    number: 15
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 11
    pin:
    number: 8
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 12
    pin:
    number: 9
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 13
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 14
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 15
    pin:
    number: 2
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 16
    pin:
    number: 3
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 17
    pin:
    number: 4
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 18
    pin:
    number: 5
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 19
    pin:
    number: 6
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 20
    pin:
    number: 7
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 21
    pin:
    number: 15
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 22
    pin:
    number: 14
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 23
    pin:
    number: 13
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 24
    pin:
    number: 12
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 25
    pin:
    number: 11
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 26
    pin:
    number: 10
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 27
    pin:
    number: 9
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 28
    pin:
    number: 8
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 29
    pin:
    number: 6
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 30
    pin:
    number: 7
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 31
    pin:
    number: 0
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 32
    pin:
    number: 1
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 33
    pin:
    number: 15
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 34
    pin:
    number: 14
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 35
    pin:
    number: 13
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 36
    pin:
    number: 12
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 37
    pin:
    number: 11
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 38
    pin:
    number: 10
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 39
    pin:
    number: 9
    mode: INPUT_PULLUP
    inverted: True
  • platform: gpio #in3 40
    pin:
    number: 8
    mode: INPUT_PULLUP
    inverted: True
Thanks to ssieb on ESPHome Discord, I found a workaround : I have to disable the restore_mode for outputs by setting :
restore_mode: ALWAYS_OFF
It seems that the the flash saving is taking too long. Probably because there’s so much data to save.
Hi @djtef - I’m curious about the project. Basically, you’re adding the MCP23017 to the device running your HA? I.e., if you were using Raspberry Pi, you’d be using something like this ModMyPi MCP23017 pHAT - 16 Channel I/O Expansion (Zero) | The Pi Hut?
And you’re using those inputs/outputs to automate your house, presumably using wired switches to collect inputs or relays to drive 240V devices?
I’ve got a zigbee-based setup, but would like to write a few things in HA, and drive some extra LEDs - seems like your project would be applicable to that.
Would be great to hear more!
Hello @bjohas
I made a board for an ESP32, not for a Raspberry Pi.
I control all my house (covers, lights, switches…) with this board which is connected to 12V Relays which drive 240V devices (covers, lights or some plugs).
One board is composed of 40 inputs and 24 outputs, I made 3 boards which are chained through i2c.
I also made a similar board with 72 inputs and 8 outputs to make an alarm.
