Hi All
I have an above-ground pool, we take it down every winter, and put it up every summer.
I’ve added a water level sensor that I put into the skimmer, with two simple sensors like these:
I detach the sensors during winter (I’ve added a waterproof three wire plug so I can detach it) as the sensors are mounted in the skimmer, and the skimmer is permanent in the lining which we stow.
Suddenly this winter, it started reporting water level too low or too high.
.I opened up the box, and went through everything, and there was a completely detached piece of wire, and I can’t figure out where it’s supposed to go. But I guess that is something to do with the ‘false’ readings.
My esphome config looks like this:
substitutions:
device_name: pool
device_description: 'Pool sensors, temperature and water height'
esphome:
comment: '${device_description}'
platform: ESP8266
board: d1_mini_pro
wifi:
ssid: !secret wifissid
password: !secret wifipw
reboot_timeout: 60min
manual_ip:
static_ip: 10.11.13.95
gateway: 10.11.13.1
subnet: 255.255.255.0
# use_address: 10.11.12.201
fast_connect: true
ap:
ssid: "${device_name} Hotspot"
password: !secret appw
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
password: !secret apipw
# encryption:
# key: !secret encryption
ota:
password: !secret otapw
#web_server:
# port: 80
# auth:
# username: !secret webuser
# password: !secret webpw
text_sensor:
- platform: version
name: '${device_name} ESPHome Version'
- platform: wifi_info
ip_address:
ssid:
time:
- platform: homeassistant
dallas:
- pin: D5
- platform: dallas
address: 0xD801144ED12FAA28
name: '${device_name} Temperature'
- platform: wifi_signal
name: '${device_name} WiFi Signal'
update_interval: 60s
accuracy_decimals: 0
- platform: uptime
unit_of_measurement: days
update_interval: 300s
accuracy_decimals: 1
filters:
- multiply: 0.000011574
binary_sensor:
- platform: gpio
filters:
- delayed_on: 1s
pin:
number: D1
mode: INPUT_PULLUP
inverted: True
name: "Water too low"
device_class: problem
- platform: gpio
filters:
- delayed_on: 1s
pin:
number: D2
mode: INPUT_PULLUP
inverted: True
name: "Water too high"
Anybody that can figure out what is wrong here, and why it is affected by cold and humidity??
