Sometimes when there is more than three or four entities in an ESPHome program, they don’t all show on the ESPHome web page. If I hit refresh on my browser some of the missing entities show and some others disappear, but never see all of them.
Apart from the usual “clear cache” and “try a different browser”, no. Is it a complex device? Maybe memory issues. Otherwise log an issue on Github, though don’t hold your breath for a solution, some there go back 2 or 3 years…
I’ve been curious about that warning about using the web server on ESP devices.
Is this the typical symptom when there’s a memory or CPU issue?
Is there a way to display memory or CPU utilization on an ESP device?
I haven’t run into any problems running the web server, but the most complex devices I’m currently using only have a handful of entities. I have no idea how far I can push the devices, or how I’d know when I’m reaching a limit.
@stevemann probably totally unhelpful … I have one little D1 Mini ESP8266; there are 24 sensors, one LED switch and one restart button. Rock solid. To be predictable; delete integration and reintegrate?? Change pins, change update interval, change power supply, fixed IP etc etc. I think you know better than me!
Does your device do any spontaneous restarts? Or by any chance you use a very ancient esphome version on that device (the behavior you describe was a known bug in the past as far as I remeber)
I am one version from the latest. I made the mistake of updating all of my devices recently and spent two more days fixing all of the new problems introduced. (Two devices would not OTA and had to be manually flashed, some of the entities created new revs: _2, _3, etc, which broke some automations and Node-Red flows). But nothing ancient.
