Hello everybody,
Today, after upgrading my esphome to version 2022.10.0, I am not able to see the device’s page from the web browser.
# Example configuration entry
web_server:
local: true
If a change the parameter “local” to false, the web server works.
The documentation says:
- local (Optional, boolean): Include supporting javascript locally allowing it to work without internet access. Defaults to
false
What has changed in this last update?
Thnak you very much for your feedback.
Max_Q
2
Don’t have an answer for you but I have the same problem!
Max_Q
3
Hi @Max_Q. Thanks for the info. I am no esphome expert so I just downgrade the version to the previous one.
LPD
(Louis-Philippe Descamps)
5
1. copy the css and js from esphome website to local pc
curl https://esphome.io/_static/webserver-v1.min.css -O webserver-v1.min.css
curl https://esphome.io/_static/webserver-v1.min.js -O webserver-v1.min.js
2. copy css and js from local pc to home assistant esphome folder
/config/esphome/dependencies/webserver/
dependencies/webserver/ are folders that I created
3. add the local files to yaml
web_server:
port: 80
css_include: "../esphome/dependencies/webserver/webserver-v1.min.css"
css_url: ""
js_include: "../esphome/dependencies/webserver/webserver-v1.min.js"
js_url: ""
