There are multiple esphome config entries with the same unique ID.
The config entries are named 'general-smartplug', 'smartplug-rumpus'.
To fix this error, configure the integration and remove all except one of the duplicates.
I have looked in the ESP dashboard and can’t see where I can edit these IDs (or where to find them).
Clicking on the configuration link listed takes me to the configuration page where it seems I can only prevent the device from performing Home Assistant actions, which is not what I want to happen.
Same problem, but even in the menu of the three dots I can not see duplicates, how to set unique ID make that possible if the next update finds that important. Solution above did help delete them all and let them re-enter. Luckily not all nodes needed deleting, pfffh
Same boat here. Sometimes the warning shows up, and it goes away by itself (not exactly sure when though). Again, I checked, and there are no duplicates.
“There are multiple esphome config entries with the same unique ID.
The config entries are named ‘pana-climate’, 'airco-zolder’”
There is no ‘pana-climate’ item in ESPhome to delete, so what do I do now?
Where did HA find that “pana-climate” entry, supposedly containing that duplicate ID?
What is that Unique ID so I can grep for that?
I’m already running several grep commands to no avail.
Without better actionable information, this error will be impossible to fix.
Hi Tom, is there a way to repair this newly introduced requirement without formatting the SSD and performing a fresh install? There appears to be no way to find the offending duplicate as it is not listed on the ESPhome dashboard.
I just went through this. No grep will find the offending device. Open the ESPHome integration and scan the “devices” column. If you see anything but a “1” in this column, then something is wrong. Double-click on “Devices” and be surprised what you find. Click on the meatball (three dots ) and delete. If there is a valid device there, Home Assistant will discover it again.
I SUSPECT, but have no proof that this happened to me because I experiment a lot and would reuse ESP modules without deleting the old device from ESPHome.
