ESPhome Whirlpool climate issue
Hello
i am using whirlpool AC ,my AC remote model is dg11j1-32
how can i control my whirpool ac with dg11j1-32 ?
i have tried it with dg11j1–3A but when i press power off it does not turn off the AC and shows heat on thermostat card .
.i really need this issue to be solved
Have you found a solution? I’m planning on doing the same thing.
Just press a button…
Maybe you should describe your hardware setup intended to control your AC…
