Hi, I’ve read all the post on this forum relating to this error but none of the suggested solutions work for me. Basically my Wemos D1, using ESP Home on one particular unit is not connecting to WiFi. I have changed the Wemos and the result is the same so I assume it’s something in my configuration but I can’t figure out what. Could someone suggest how to get around this?
The error
And the ESP Configuration:
esphome:
platform: ESP8266
board: d1_mini_pro
wifi:
manual_ip:
static_ip: 192.168.1.20
gateway: 192.168.1.254
subnet: 255.255.255.0
networks:
- ssid: !secret wifi_ssid
logger:
api:
ota:
i2c:
sda: D2
scl: D1
scan: true
- platform: homeassistant
entity_id: sensor.outside_humidity
internal: true
entity_id: sensor.outside_temperature
internal: true
entity_id: sensor.outside_illuminance
internal: true
entity_id: sensor.weather_today_max_temp
internal: true
entity_id: sensor.weather_today_min_temp
internal: true
entity_id: sensor.kitchen_pressure
internal: true
entity_id: sensor.kitchen_temperature
internal: true
- platform: bme280
temperature:
name: "Kitchen Temperature"
oversampling: 16x
filters:
- calibrate_linear:
# # Map 0.0 (from sensor) to 0.0 (true value)
- 27.5 -> 24.5
- 20.0 -> 18.6
- 18.8 -> 17.0
- 19.2 -> 17.6
pressure:
name: "Kitchen Pressure"
address: 0x76
update_interval: 20s
binary_sensor:
- platform: gpio
pin: 14
device_class: motion
on_press:
then:
- binary_sensor.template.publish:
state: ON
state: OFF
filters:
- delayed_off: 90s
on_press:
then:
- lambda: |-
id(my_display).backlight();
// it.print(0,19,".");
on_release:
then:
- lambda: |-
id(my_display).no_backlight();
// it.print(0,19," ");
display:
- platform: lcd_pcf8574
dimensions: 20x4
address: 0x27
lambda: |-
// How to use character based display: https://esphome.io/components/display/lcd_display.html
// id(my_display).no_backlight();
// Check above link to see how to manage backlight using motion sensor
it.print(0,0,"Initializing...");
// Print the current time
auto timeVar = id(homeassistant_time).now();
if (timeVar.is_valid()) {
it.strftime(0,1,"%H:%M:%S ",timeVar);
it.printf(13,1,"%4.0f lx", id(outside_illuminance).state);
it.strftime(0,0,"%a %d %b %Y", timeVar);
// Result for 10:06 on august 21st 2018 -> "It is 10:06 on 21.08.2018"
// Outside Measurements
// Example of how to display homeassistant data in ESPHome: https://esphome.io/cookbook/display_time_temp_oled.html
// sensor.outside_temperature
if (id(outside_temp).has_state()) {
if (id(outside_temp).state < 10) {
it.printf(0,2,"Out: %02.1f", id(outside_temp).state);
else {
if ((id(outside_min_temp).has_state()) && (id(outside_max_temp).has_state())) {
it.printf(9,2," (%0.0f to %0.0f) ", id(outside_min_temp).state,id(outside_max_temp).state);
if (id(kitchen_temp).has_state()) {
it.printf(0,3,"In : %02.1f", id(kitchen_temp).state);
if (id(outside_humidity).has_state()) {
it.printf(12,3,"Hum: %02.0f%%", id(outside_humidity).state);
//it.print(19,3,"%");
# (Optional) For displaying time:
time:
