My esp8266 isn’t able to recover from deep sleep via wifi.
It’s a simple setup with my esp8266 with a BME280 with pins D0 connected to RST. Without any deep sleep configured, the unit successfully provides sensor values every 10s but as soon as I configure the deep sleep it never re-connects to the esp8266 via wifi. The sensor update interval is 10s, deep sleep run duration is 30s (so should be plenty of time for the unit to recover and resend sensor values within the 30s window) and a deep sleep duration of 3 min. …as per code and logs below.
A very simple setup but can’t figure out why I can’t reconnect.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "RobsBillion-2.4g"
password: "#############"
power_save_mode: none
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.1.133
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.1.254
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
i2c:
sda: D2
scl: D1
- platform: bme280
temperature:
name: "Outdoor Temperature"
oversampling: 16x
pressure:
name: "Outdoor Pressure"
humidity:
name: "Outdoor Humidity"
address: 0x76
update_interval: 10s
- platform: wifi_signal
name: "Outdoor WiFi Signal"
- platform: adc
pin: A0
name: "Outdoor battery voltage"
filters:
- multiply: 15.42
deep_sleep:
run_duration: 30s
sleep_duration: 3min
Uploading: [============================================================] 100% Done…
INFO Waiting for result…
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.1.133 using esphome API
INFO Connecting to 192.168.1.133:6053 (192.168.1.133)
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 192.168.1.133: timed out). Re-Trying in 1 seconds
INFO Successfully connected to 192.168.1.133
[20:20:12][I][app:095]: esphome version 1.13.4 compiled on Jun 6 2019, 20:19:38
[20:20:12][C][wifi:368]: WiFi:
[20:20:12][C][wifi:250]: SSID:[redacted]
[20:20:12][C][wifi:251]: IP Address: 192.168.1.133
[20:20:12][C][wifi:253]: BSSID:[redacted]
[20:20:12][C][wifi:254]: Hostname: ‘outdoor_bme280’
[20:20:12][C][wifi:258]: Signal strength: -53 dB ▂▄▆█
[20:20:12][C][wifi:259]: Channel: 10
[20:20:12][C][wifi:260]: Subnet: 255.255.255.0
[20:20:12][C][wifi:261]: Gateway: 192.168.1.254
[20:20:12][C][wifi:262]: DNS1: 0.0.0.0
[20:20:12][C][wifi:263]: DNS2: 0.0.0.0
[20:20:12][D][bme280.sensor:197]: Got temperature=23.6°C pressure=1001.7hPa humidity=37.1%
[20:20:12][D][sensor:092]: ‘Outdoor Temperature’: Sending state 23.56000 °C with 1 decimals of accuracy
[20:20:12][D][sensor:092]: ‘Outdoor Pressure’: Sending state 1001.65283 hPa with 1 decimals of accuracy
[20:20:12](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[20:20:12][C][i2c:028]: I2C Bus:
[20:20:12][C][i2c:029]: SDA Pin: GPIO4
[20:20:12][C][i2c:030]: SCL Pin: GPIO5
[20:20:12][C][i2c:031]: Frequency: 50000 Hz
[20:20:12][I][i2c:033]: Scanning i2c bus for active devices…
[20:20:13][I][i2c:040]: Found i2c device at address 0x76
[20:20:13][C][logger:137]: Logger:
[20:20:13][C][logger:138]: Level: DEBUG
[20:20:13][C][logger:139]: Log Baud Rate: 115200
[20:20:13][C][logger:140]: Hardware UART: UART0
[20:20:13][C][bme280.sensor:142]: BME280:
[20:20:13][C][bme280.sensor:143]: Address: 0x76
[20:20:13][C][bme280.sensor:155]: IIR Filter: OFF
[20:20:13][C][bme280.sensor:156]: Update Interval: 10.0s
[20:20:13][C][bme280.sensor:158]: Temperature ‘Outdoor Temperature’
[20:20:13][C][bme280.sensor:158]: Unit of Measurement: ‘°C’
[20:20:13][C][bme280.sensor:158]: Accuracy Decimals: 1
[20:20:13][C][bme280.sensor:158]: Icon: ‘mdi:thermometer’
[20:20:13][C][bme280.sensor:159]: Oversampling: 16x
[20:20:13][C][bme280.sensor:160]: Pressure ‘Outdoor Pressure’
[20:20:13][C][bme280.sensor:160]: Unit of Measurement: ‘hPa’
[20:20:13][C][bme280.sensor:160]: Accuracy Decimals: 1
[20:20:13][C][bme280.sensor:160]: Icon: ‘mdi:gauge’
[20:20:13][C][bme280.sensor:161]: Oversampling: 16x
[20:20:13][C][bme280.sensor:162]: Humidity ‘Outdoor Humidity’
[20:20:13][C][bme280.sensor:162]: Unit of Measurement: ‘%’
[20:20:13](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[20:20:13][C][bme280.sensor:163]: Oversampling: 16x
[20:20:13][C][adc:026]: ADC Sensor ‘Outdoor battery voltage’
[20:20:13][C][adc:026]: Unit of Measurement: ‘V’
[20:20:13][C][adc:026]: Accuracy Decimals: 2
[20:20:13][C][adc:026]: Icon: ‘mdi:flash’
[20:20:13][C][adc:031]: Pin: 17
[20:20:13][C][adc:051]: Update Interval: 10.0s
[20:20:13][C][ota:029]: Over-The-Air Updates:
[20:20:13][C][ota:030]: Address: 192.168.1.133:8266
[20:20:13][C][api:102]: API Server:
[20:20:13][C][api:103]: Address: 192.168.1.133:6053
[20:20:13][C][wifi_signal.sensor:009]: WiFi Signal ‘Outdoor WiFi Signal’
[20:20:13][C][wifi_signal.sensor:009]: Unit of Measurement: ‘dB’
[20:20:13][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[20:20:13][C][wifi_signal.sensor:009]: Icon: ‘mdi:wifi’
[20:20:13][C][deep_sleep:020]: Setting up Deep Sleep…
[20:20:13][C][deep_sleep:023]: Sleep Duration: 180000 ms
[20:20:13][C][deep_sleep:026]: Run Duration: 30000 ms
[20:20:13][D][api:572]: Client ‘Home Assistant 0.93.2 (192.168.1.120)’ connected successfully!
[20:20:18][D][sensor:092]: ‘Outdoor WiFi Signal’: Sending state -54.00000 dB with 0 decimals of accuracy
[20:20:22][D][adc:056]: ‘Outdoor battery voltage’: Got voltage=0.27V
[20:20:22][D][sensor:092]: ‘Outdoor battery voltage’: Sending state 4.11100 V with 2 decimals of accuracy
[20:20:22][D][bme280.sensor:197]: Got temperature=23.6°C pressure=1001.7hPa humidity=37.2%
[20:20:22][D][sensor:092]: ‘Outdoor Temperature’: Sending state 23.56000 °C with 1 decimals of accuracy
[20:20:22][D][sensor:092]: ‘Outdoor Pressure’: Sending state 1001.65625 hPa with 1 decimals of accuracy
[20:20:22][D][sensor:092]: ‘Outdoor Humidity’: Sending state 37.16406 % with 1 decimals of accuracy
[20:20:28][D][sensor:092]: ‘Outdoor WiFi Signal’: Sending state -52.00000 dB with 0 decimals of accuracy
[20:20:32][D][adc:056]: ‘Outdoor battery voltage’: Got voltage=0.27V
[20:20:32][D][sensor:092]: ‘Outdoor battery voltage’: Sending state 4.11100 V with 2 decimals of accuracy
[20:20:32][D][bme280.sensor:197]: Got temperature=23.6°C pressure=1001.7hPa humidity=37.1%
[20:20:32][D][sensor:092]: ‘Outdoor Temperature’: Sending state 23.56000 °C with 1 decimals of accuracy
[20:20:32][D][sensor:092]: ‘Outdoor Pressure’: Sending state 1001.65967 hPa with 1 decimals of accuracy
[20:20:32][D][sensor:092]: ‘Outdoor Humidity’: Sending state 37.14160 % with 1 decimals of accuracy
[20:20:38][D][sensor:092]: ‘Outdoor WiFi Signal’: Sending state -53.00000 dB with 0 decimals of accuracy
WARNING Disconnected from API: Timeout while waiting for message response!
WARNING Couldn’t connect to API (Error connecting to 192.168.1.133: timed out). Trying to reconnect in 1 seconds
WARNING Couldn’t connect to API (Error connecting to 192.168.1.133: timed out). Trying to reconnect in 2 seconds
WARNING Couldn’t connect to API (Error connecting to 192.168.1.133: timed out). Trying to reconnect in 4 seconds
WARNING Couldn’t connect to API (Error connecting to 192.168.1.133: [Errno 113] No route to host). Trying to reconnect in 8 seconds
WARNING Couldn’t connect to API (Error connecting to 192.168.1.133: [Errno 113] No route to host). Trying to reconnect in 16 seconds
WARNING Couldn’t connect to API (Error connecting to 192.168.1.133: [Errno 113] No route to host). Trying to reconnect in 32 seconds
WARNING Couldn’t connect to API (Error connecting to 192.168.1.133: [Errno 113] No route to host). Trying to reconnect in 64 seconds
WARNING Couldn’t connect to API (Error connecting to 192.168.1.133: [Errno 113] No route to host). Trying to reconnect in 128 seconds
WARNING Couldn’t connect to API (Error connecting to 192.168.1.133: [Errno 113] No route to host). Trying to reconnect in 256 seconds
WARNING Couldn’t connect to API (Error connecting to 192.168.1.133: [Errno 113] No route to host). Trying to reconnect in 300 seconds
