I’m having nothing but trouble trying to get these displays working. This isn’t rocket science but it sure feels like it.
I get a lit up but completely blank screen, no test card.
My config:
spi:
clk_pin: GPIO25
mosi_pin: GPIO26
miso_pin: GPIO4
display:
- platform: ili9xxx
model: ILI9341 # I've tried every available option here.
cs_pin: GPIO32
dc_pin: GPIO22
reset_pin: GPIO27
rotation: 0
invert_colors: false
show_test_card: false
lambda: |-
it.print(1, 175, id(font20), id(status_msg).state.c_str());
it.print(1, 2, id(font30), "Power");
it.print(105, 2, id(font30), "Smoke");
if (id(go).state) {
//it.print(20, 75, id(font30), "ON");
it.filled_rectangle(40, 40, 30, 42);
} else {
//it.print(20, 75, id(font30), "OFF");
it.rectangle(40, 40, 30, 42);
if (id(smoke_mode).state) {
//it.print(115, 75, id(font30), "ON");
it.filled_rectangle(140, 40, 30, 42);
} else {
//it.print(115, 75, id(font30), "OFF");
it.rectangle(140, 40, 30, 42);
//smoker_set_temp on left
it.print(1, 90, id(font20), "Set Temp");
it.printf(0, 110, id(font45), "%.0f°", id(smoker_set_temp).state);
//smoker_rtd_temperature on right
it.print(105, 90, id(font20), "RTD Temp");
it.printf(107, 110, id(font45), "%.0f°", id(smoker_rtd_temperature).state);
font:
- file: "gfonts://Roboto"
the log output
18:49:49][C][spi:064]: SPI bus:
[18:49:49][C][spi:065]: CLK Pin: GPIO25
[18:49:49][C][spi:066]: SDI Pin: GPIO4
[18:49:49][C][spi:067]: SDO Pin: GPIO26
[18:49:49][C][spi:072]: Using HW SPI: SPI
[18:49:49][C][i2c.arduino:071]: I2C Bus:
[18:49:49][C][i2c.arduino:072]: SDA Pin: GPIO10
[18:49:49][C][i2c.arduino:073]: SCL Pin: GPIO5
[18:49:49][C][i2c.arduino:074]: Frequency: 50000 Hz
[18:49:49][C][i2c.arduino:086]: Recovery: bus successfully recovered
[18:49:49][I][i2c.arduino:096]: Results from i2c bus scan:
[18:49:49][I][i2c.arduino:098]: Found no i2c devices!
[18:49:49][C][ili9xxx:094]: ili9xxx
[18:49:49][C][ili9xxx:094]: Rotations: 0 °
[18:49:49][C][ili9xxx:094]: Dimensions: 240px x 320px
[18:49:49][C][ili9xxx:095]: Width Offset: 0
[18:49:49][C][ili9xxx:096]: Height Offset: 0
[18:49:49][C][ili9xxx:105]: Color mode: 8bit 332 mode
[18:49:49][C][ili9xxx:111]: Data rate: 40MHz
[18:49:49][C][ili9xxx:113]: Reset Pin: GPIO27
[18:49:49][C][ili9xxx:114]: CS Pin: GPIO32
[18:49:49][C][ili9xxx:115]: DC Pin: GPIO22
[18:49:49][C][ili9xxx:117]: Color order: BGR
[18:49:49][C][ili9xxx:118]: Swap_xy: NO
[18:49:49][C][ili9xxx:119]: Mirror_x: YES
[18:49:49][C][ili9xxx:120]: Mirror_y: NO
[18:49:49][C][ili9xxx:121]: Invert colors: NO
[18:49:49][C][ili9xxx:126]: Update Interval: 1.0s
... other messages, then this endlessly repeating msg
19:12:22][W][component:237]: Component display took a long time for an operation (89 ms).
[19:12:22][W][component:238]: Components should block for at most 30 ms.
[19:12:23][W][component:237]: Component display took a long time for an operation (89 ms).
[19:12:23][W][component:238]: Components should block for at most 30 ms.
[19:12:24][W][component:237]: Component display took a long time for an operation (89 ms).
[19:12:24][W][component:238]: Components should block for at most 30 ms.
[19:12:25][W][component:237]: Component display took a long time for an operation (89 ms).
[19:12:25][W][component:238]: Components should block for at most 30 ms.
[19:12:26][W][component:237]: Component display took a long time for an o
I’ve tried various other model: types, all giving only these 3 lines in the ili9xxx section of the log:
[18:58:16][D][ili9xxx:034]: Setting up ILI9xxx
[18:58:16][D][spi_device:362]: mode 0, data_rate 40000kHz
[18:58:17][D][ili9xxx:030]: Wrote MADCTL 0x48
The only model that gives full info is model: ILI9341
Is there a trick to getting this display working? I must be missing something really basic here. Hours of wasted time! I have 4 of these displays and they all are blank.
I have an e-paper display working right out of the gate, but it’s not going to work for my application. I used the same basic pins for it, so the ESP32 is working just fine.
