ESPHome with NodeMCU, discovered but can't configure
I have this issue when I try to connect a second nodemcu to homeassistant via esphome. It shows up as discovered and I get readings from the sensor on the logs, but I can’t configure it in homeassistant. Nothing happens when I press configure, I am only able to ignore the device. I have tried rebooting home assistant and esphome.
Are you giving each node a unique name?
Yes. I have named them nodemcu1 and nodemcu2, is this an issue? The other one is disconnected now, only the nodemcu2 is connected.
Is there anything I’m missing?
It worked after the latest update.
