ESPHome with Sonoff 4CH Pro R1 relays curious beahavior
I just flashed an old Sonoff 4CH Pro R1 with ESPHome configured with the code sample from ESPHome web site.
Every relay is working individually but not when I switch on multiple relays, it doesn’t work.
Any suggestion on what could be wrong?
esphome:
  friendly_name: Sonoff R1
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "hqI0ptQVr+7TlMmX1q8TGRQOBl/mKjXaZ6DXKkT+TQA="
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-8606Ae"
    password: "YrgRLs7ZyTYW"
captive_portal:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode:
        input: true
        pullup: true
      inverted: true
    name: "Sonoff 4CH Button 1"
    filters:
      - delayed_on: 50ms
  - platform: gpio
    pin:
      number: GPIO9
      mode:
        input: true
        pullup: true
      inverted: true
    name: "Sonoff 4CH Button 2"
    filters:
      - delayed_on: 50ms
  - platform: gpio
    pin:
      number: GPIO10
      mode:
        input: true
        pullup: true
      inverted: true
    name: "Sonoff 4CH Button 3"
    filters:
      - delayed_on: 50ms
  - platform: gpio
    pin:
      number: GPIO14
      mode:
        input: true
        pullup: true
      inverted: true
    name: "Sonoff 4CH Button 4"
    filters:
      - delayed_on: 50ms
  - platform: status
    name: "Sonoff 4CH Status"
switch:
  - platform: gpio
    name: "Sonoff 4CH Relay 1"
    pin: GPIO12
  - platform: gpio
    name: "Sonoff 4CH Relay 2"
    pin: GPIO5
  - platform: gpio
    name: "Sonoff 4CH Relay 3"
    pin: GPIO4
  - platform: gpio
    name: "Sonoff 4CH Relay 4"
    pin: GPIO15
output:
  # Register the blue LED as a dimmable output ....
  - platform: esp8266_pwm
    pin: GPIO13
    inverted: true
light:
  # ... and then make a light out of it.
  - platform: monochromatic
    name: "Sonoff 4CH Blue LED"
    output: blue_led
There are switches on the board that control the relay modes. You need to set them to self-locking (for independent control of the relays):
https://wiki.iteadstudio.com/Sonoff_4CH_Pro
So:
S6 → 1
K5 (switches 1 to 4) → 1
K6 (switches 1 to 4) → doesn’t matter.
S5 → doesn’t matter.
4CH-Pro
You are my hero for today. Thank you so much for your previous help !
I will try it right now !
