Question:
I have a sonoff basic with a pir sensor on GPIO14.
Normally the automation is done by HomeAssistant but if its down ( rebooting / wifi down or what ever) the automation isn’t there anymore. So the lights wont go on.
The automation in HA is like this :
- alias: '[PIR] Kledingkast on'
- platform: state
entity_id: binary_sensor.kledingkast_pir
to: 'on'
- service: switch.turn_on
entity_id:
- switch.kledingkast
- alias: '[PIR] Kledingkast off after 50 seconds'
- platform: state
to: 'off'
for:
seconds: 50
condition:
- condition: state
entity_id: switch.kledingkast
state: 'on'
- service: switch.turn_off
entity_id:
How can I make this work in esphome so that the automation is done within esphome-sonoff?
The thing is that in esphome the relay is acting like a toggle switch. So every time there is movement its toggling the relay on and off…
what I need is a if then else I guess… and some sort of dummy sensor with will be on or off
this is my esphome yaml :
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Sonoff Basic Button"
on_press:
- switch.turn_on: relay
- platform: gpio
pin: GPIO14
device_class: motion
on_press:
lambda: 'return id(my_motion).state;'
filters:
- delayed_off: 1min
on_release:
- switch.turn_off: relay
switch:
- platform: gpio
name: "Sonoff Basic Relay"
pin: GPIO12
status_led:
pin:
number: GPIO13
inverted: yes
but thats not working as I want it to work
update:
had to make it switch.turn_on/off instead of toggle
