Klagio
(Klagio)
1
Hi, today I had a crash on my HASS server, and wished to use a Sonoff switch urgently, and of course I could not.
So as a backup I wish to be able to control the switch also without HASS for those cases. I tried but did not succed.
My switch art of the Sonoff POW R1 flashed is this below (it works perfectly in HASS)
switch:
optimistic: true
turn_on_action:
- switch.turn_on: relay
- light.turn_on: led
turn_off_action:
- switch.turn_off: relay
- light.turn_off: led
- platform: gpio
pin: GPIO12
and I gave this POST command, but the switch did not turn on. Where is my mistake?
http://192.168.1.7/switch/guest_room_tv_power_plug/turn_on
Perhaps some help here? Not sure though.
nickrout
(Nick Rout)
3
To use the rest API you need to configure the http component. https://esphome.io/components/web_server.html
I have mine setup so that the button on the sonoff triggers the relay. This only works if your sonoff is in an accessible place of course…
add the web_server:
component to your device, and then simply browse to the device’s ip address.
All switches and sensors will be in the web frontend.
Klagio
(Klagio)
6
I had that.
After a restart its working, don’t know what happened.
@OttoWinter Love this ESPHome, absolutely love it. Very cool. I am not buying any WiFi device if cannot be flashed with ESPHome.
BTW any chance that Yeelight lightbulbs can be flashed with ESPhome, maybe in the future, or is technically impossible?
