Hi All,
I feel like I’m probably missing something really obvious here but I’m failing at the starters gate in trying to get ESPHome to run. I have followed this tutorial on both a Windows 10 and a Ubuntu installation and in both cases I’m getting the following error launching ESPHome:
C:\Python27\Scripts>esphome
File "c:\python27\lib\runpy.py", line 162, in _run_module_as_main
"__main__", fname, loader, pkg_name)
File "c:\python27\lib\runpy.py", line 72, in _run_code
exec code in run_globals
File "C:\Python27\Scripts\esphome.exe\__main__.py", line 5, in <module>
File "c:\python27\lib\site-packages\esphome\__main__.py", line 10, in <module>
from esphome import const, writer, yaml_util
File "c:\python27\lib\site-packages\esphome\writer.py", line 7, in <module>
from esphome.config import iter_components
File "c:\python27\lib\site-packages\esphome\config.py", line 15, in <module>
from esphome import core, core_config, yaml_util
File "c:\python27\lib\site-packages\esphome\core_config.py", line 6, in <module>
import esphome.config_validation as cv
File "c:\python27\lib\site-packages\esphome\config_validation.py", line 1242, in <module>
Optional(CONF_COMMAND_TOPIC): All(requires_component('mqtt'), subscribe_topic),
File "c:\python27\lib\site-packages\esphome\voluptuous_schema.py", line 198, in extend
ret = super(_Schema, self).extend(schema, extra=extra)
File "c:\python27\lib\site-packages\voluptuous\schema_builder.py", line 782, in extend
return result_cls(result, required=result_required, extra=result_extra)
TypeError: __init__() got an unexpected keyword argument 'required'
I’m not really familiar with Python but I’m assuming this is nothing to do with the Python installation or paths as it is almost the same error dump on both Windows and Ubuntu. The line 162 - line 5 section is missing in Ubuntu but from line 10 down it is the same.
I’d be really grateful if anyone could provide advice on how to get this working.
Phil
