Esphomelib and WIFI connection
i know it has already been discussed probably here and in other places.
Few references below:
Sonoff Device not connecting to WiFi
Unstable MQTT connection
Esphomelib arduino framework versions
ESPhomelib FAQs
But still…my 2 sonoff basics and Sonoff S20 keeps disconnecting very frequently.
They were reasonable once flashed with 1.8.2 version, then upgrade to latest platformIO (3.6.2) and latest Esphomelib (1.9.3) flashed and…situation is now similar to pre 1.8 version.
I followed the above suggestion but:
  • setting “arduino_version: latest” esphomelib complains “it is not a valid option for esphomeyaml”
esphomeyaml:
  platform: ESP8266
  board: esp01_1m
  board_flash_mode: dout
  • setting “power_save_mode: light” esphomelib complains “it is not a valid option for wifi”
wifi:
  ssid: 'myssid'
  password: 'mypass'
so I am a bit stuck in trying.
Also I see people reporting having solved the issue using a specific arduino framework version although I did not understand which one is suggested to mitigate the issue.
@OttoWinter can you be so kind to provide some advice? :slight_smile:
I suspect you’re using esphomelib v1.7.x or something even before that. Maybe that could have been caused by a virtualenv issue?
You can check which version of esphomeyaml you’re using with esphomeyaml <YAML_FILE> version - if that shows an issue you’re using an ancient version of esphomeyaml :wink:
https://esphomelib.com/esphomeyaml/guides/faq.html#how-do-i-update-to-the-latest-version
hi @OttoWinter,
i think you made it.
So if i run:
i get 1.7.0 (DAMN!!!), while if i run
sudo esphomeyaml <YAML_FILE> version
i get 1.9.3 :frowning:
it is not clear to me how can I have 2 different install though…sorry for the fuss
