Starting to play around with esphomelib i am trying to build a sprinkler controller with it. so far for a simple turn on and turn off i have one relay working, just need to duplicate code to get the rest working.
What i am trying to figure out a way that i can pass the amount of time i want the realy to stay one using mqtt. say one day i want it to trigger for 15 mins but the next only 10 min. rather then hard coding with a set time or relying on home assistant to control the relay directly. I can see this being a benefit in the fact that if homeassistant or something goes wrong i have a lesser chance of the water staying on till i find it.
Yes i could code the entire thing my self but i am trying out this new library, so ya.
Your best be would be to pass the time to the ESP with MQTT subscribe:
Write an automation in HA to publish an input_number’s value to the topic (retained) when the input number is changed.
I’m a little fuzzy on how you would use this data as I haven’t used templates (lambda) in ESPhome yet. Seems to be pretty similar to the way it is done in HA:
EDIT: also that’s a good idea about making it as independent from HA as possible.
Thank you, i think that is what i am looking for. If i use a global variable and use mqtt to change that and then call that global variable to set the delay. If i was just coding it using c++ it would be pretty straight forward. Trying to wrap my head around this. Also going to have to figure out to do this with out delay, I guess what i need to do is figure out how to bury some c++ code inside…as i don’t want it to hang while it is waiting for 15 mins for a zone to go off.
As for making it independent, that is my main goal of everything. I want every unit to operate as independent as possible if anything is going wrong. This is the main reason that i switched from tasmota to espurna, i didn’t like how tasmota would lock up if the unit lost wifi. ESPHOMELIB looks interesting so i figured i would give it a shot as i was building the sprinkler controller anyways figured it would be a good platform to test it out before i tried it on anything else.
Interesting, if anyone runs across it but i just realized that delay in esphomelib is not a true c++ delay, well that’s what they say anyways, i will test it to night but they claim it to be a ““smart” asynchronous delay”. So we will see…
OK, in need of some help, any idea how to pass time, well nicer time…
I am using a global variable then using the following to return that variable to to control the delay. the problem is i seem to be setting the time in ms… ok i am not really sure what i am actually setting the time in is my first problem.
- delay: !lambda |-
return id(zone_run_time);
I have two ideas to fix this A: do math on the variable inside the function so i could set the variable in min but it would be converted in the function, but i need to know what unit of measure it defaults to when is doesn’t have a descriptor , or B: is there a way that i can add “min” to the end of the variable?
Maybe you should’ve posted in the esphomelib section so the main dev sees this thread. I haven’t ever opened a thread can you change it if you edit your opening post to edit the category?
