Espixelstick Automation or Control?
I’m not sure if what I want to do is possible or not,so I’ll see what you guys/gals think.
I have a Esp8266 esp-01 that controls some Christmas lights. Right now I have to load a webpage and then start the lights and then open the webpage and turn them off.
I would like to either get them into HA so I can just turn them on and off or create some sort of automation that would turn them on and off at a certain time. IS this even possible?
I have some nodemcu and Wemos mini d1 that I can flash with the firmware if that would help things.
I think this is something that you may want to look into. This also has an integration in Homeassistant, which will allow you to create automation’s to turn the lights on and off.
