I got interested in “irrigation rings” to disperse water more evenly so am tineking with some 3d printable designs based on what I’ve seen online. Doubt they’ll hold up super well in the long term, but let’s see…
Dear @Mahko_Mahko
Very nice post.
I was just testing you ESP Code. It is very nice!!!
I was wondering why you are using “input_boolean.defeat_sleep” with a helper and not a dedicated switch for this device?
Did you tried such a solution?
Regards
Adrian
I’ve refined the config more which I’ll repost soonish.
I was considering having both wake options.
The remote virtual switch doesn’t require any hardware.
A button/switch would need to be weatherproofed.
I may still add one.
I recall that a wake button is better than a wake switch. Something about it being hard to determine the true state of a switch on boot. Might be wrong though.
The virtual switch can’t be on the device as when it is in deep sleep it will not track the state as changed in HA / retrieve the changed state when it wakes (I think).
I would prefer that but it doesn’t seem to work as you might want. Let me know if you find otherwise.
Interesting project. I just started something simular for my balcony. No plumbing and no power outlet.
I ordered some parts from Aliexpress. As for now it is enough for 8 plants, expandable to 16. I use a 8-relay board with onboard ESP, with an extra 8-relay board I can expand it to 16.
Each plant has it’s own micropump. The idea is to measure the moisture and when it’s on the minimum the according pump starts for a defined time to water it to the max level. I want to do that with some interruptions to get a more accurate measuring of the moisture level. The main hose comes from the tank, goes tot an 8-fold divider. From there there goes a hose to every pump.
I just received all the parts and programmed the ESP so it is visible in Home Assistant, so I’m not that far yet
The new system has a VL53L0X. I’m still working through some reliability issues. Might be connections. Stops reporting when battery voltage gets lower. But generally works well. Much smaller than an ultrasonic.
The old system doesn’t have anything. I got a float switch which I was going to use with an aqara reed switch but I never got around to installing it.
I think I was originally going to pop one of these in the bottom but the signal range didn’t seem to be good and I don’t think they’re really supposed to be immersed.
AU $23.31 48%OFF | Aqara Flood Sensor Water Immersing Sensor IP67 Waterproof Remote Alarm Work With Smart home app https://a.aliexpress.com/_msHN9me
