šŸŒæ ESPlanty | Self-watering Solar Powered Plant | No plumbing & no powerpoints | # Irrigation , # Deep Sleep , # Battery
Iā€™ll maintain my master config here. May not maintain it well though.
Edit: Fresh paste on 2024-01-13
#Todo:
  #Determine night time battery loss.
  #More testing insitu
  #HA alerts for low water, low battery, data updates not working.
  #Check pump runs.
  #Monitor review wet/dry/battery thresholds.
  #Make debugging sensors internal.
substitutions:
  sleep_time: 60min
  auto_wake_time: 20s
  pump_run_time: 10s
  internal_mode: "true"
  long_deep_sleep_duration: 24h
  bh1750_i2c_scl_blue: GPIO27
  bh1750_i2c_sda_green: GPIO25
  vl53l0x_i2c_scl_blue: GPIO23
  vl53l0x_i2c_sda_green: GPIO05
  power_peripheral_pin: GPIO26
  pump_switch_pin: GPIO18
  batt_voltage_pin: GPIO33
  soil_moisture_pin: GPIO34
# G                        # RST                            #1 tx         # G
# NC                       # VP                             #3 rx         #@ 27 bh1750 blue scl  ${bh1750_i2c_scl_blue}
# VN                       #@ 26 ${power_peripheral_pin}    #22           #@ 25 bh1750 green sda ${bh1750_i2c_sda_green}
# 35                       #@ 18 ${pump_switch_pin}         #21           #@ 32
#@ 33 ${batt_voltage_pin}  #@ 19                            #27           # TDI
# 34 ${soil_moisture_pin}  #@ 23 ${vl53l0x_i2c_scl_blue}    #25           #@ 4
# TMS                      #@ 5  ${vl53l0x_i2c_sda_green}   #G            # 0
# NC                       # 3v3                            #5v           # 2
# SD2                      # TCK                            #TDO          # SD1
# CMD                      # SD3                            #SDO          # CLK
esp32:
  board: ttgo-t7-v14-mini32 #pinout: https://ae01.alicdn.com/kf/Ha204b20d14d243faa0c1a8760de1b187r.jpg
esphome:
  friendly_name: ESPlanty
  comment: Balcony Solar Irrigation
  on_boot:
    # #Try this if sensors don't boot. https://community.home-assistant.io/t/add-sensor-delay-upon-power-on/158567/6?u=mahko_mahko
    # https://community.home-assistant.io/t/i2c-bus-scan-after-deep-sleep-recovery/524925/7?u=mahko_mahko
    - priority: 900
      then:
      - lambda: |-
          Wire.begin();
          delay(500);
    - priority: -100
      then:
        #Reset sensor update counters. These are for debugging.
        - lambda: id(count_irrigation_lux).publish_state(0);
        - lambda: id(count_batt_voltage).publish_state(0);
        - lambda: id(count_irrigation_tof).publish_state(0);
        - delay: 1s
        #Auto sensor updates are turned off and manually requested on boot. These are multi-sampled and then aggregated.
        #The ESP then goes back to sleep when they're done (unless told to stay awake).
          #Request sensor updates
        - logger.log: "....Starting sensor updates"
        - repeat:
            count: 5 #Update cycles
            then:
              - component.update: batt_voltage #Battery level
              - delay: 100ms
              - component.update: soil_moisture_voltage #Moisture level
              - delay: 100ms
              - component.update: tof #Water tank level
              - delay: 100ms
              - component.update: irrigation_lux #Light level
              - delay: 100ms
            #second pass for ADC based sensors which benefit from more samples.
              - delay: 200ms
              - delay: 200ms
              - delay: 100ms
  on_shutdown: #Includes deep sleep
    priority: -100
    then:
      - script.wait: run_pump_for_pump_run_time #Wait until pump run is done.
      - if:
            - binary_sensor.is_on: all_updates_recieved
          then:
            - logger.log: "Data updates ok..."
          else:
            - logger.log: "A sensor might be down...missing updates"
            - binary_sensor.template.publish:
                state: ON
            - delay: 1s
      - switch.turn_off: pump #Probably not required....
    #Turn off 5v peripheral power. It will retore as on when it wakes.
      - logger.log: "Turning off peripheral power..."
      - switch.turn_off: power_peripherals
    #Turn off the "Fresh data recieved sensors"
          state: OFF
          state: OFF
          state: OFF
          state: OFF
          state: OFF
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  manual_ip:
      static_ip: 192.168.1.123
      gateway: 192.168.1.1
      subnet: 255.255.255.0
api:
ota:
logger:
  level: VERBOSE
  baud_rate: 0
i2c:
  - id: bh1750_i2c_bus
    sda: GPIO25 #data > green wire
    scl: GPIO27 #clock > blue wire
    scan: true
  - id: vl53l0x_i2c_bus
    sda: ${vl53l0x_i2c_sda_green} #data > green wire
    scl: ${vl53l0x_i2c_scl_blue} #clock > blue wire
    scan: true
deep_sleep:
#Auto deep sleep shouldn't actually get used if data updates are happening properly (should sleep sooner).
#But if something is wrong with data updates this will kick-in to protect battery discharge.
  run_duration: ${auto_wake_time}
  sleep_duration: ${sleep_time}
time:
  - platform: homeassistant
    on_time:
      #Deep sleep at 8pm and wake up at 6am.
      - hours: 20
        then:
          #Publish battery level to the end of day sensor since it will be our last update.
          - lambda: return id(end_of_day_battery_percent).publish_state(id(batt_level).state);
          #Reset culmulative light sensor reset
          - sensor.integration.reset: irrigation_cul_lux_hours
          - delay: 1s
          #Rest up
          - deep_sleep.enter:
              until: "06:00:00"
              time_id: esptime
text_sensor:
 # Reports the ESPHome Version with compile date
  - platform: version
select:
#Watering Mode.
  #Watering regime allows plant to become quite dry and then get a good watering,
  #as opposed to more frequent bang bang watering cycles.
#TODO: More testing.
    optimistic: true
    restore_value: true
    options:
      - Wetting Mode
      - Drying Mode
    initial_option: Drying Mode
number:
#Upper mositure target (once dry)
    name: Moisture Upper Target
    icon: mdi:arrow-collapse-up
    optimistic: true
    unit_of_measurement: '%'
    min_value: 40.0
    max_value: 90.0
    step: 5.0
    restore_value: true
    initial_value: 80.0
#Lower Water threshold (triggers watering regime). Need to establish good values.
    name: Moisture Lower Threshold
    icon: mdi:arrow-collapse-down
    optimistic: true
    min_value: 5.0
    max_value: 60.0
    step: 5.0
    restore_value: true
    initial_value: 50.0
#Battery Saving Mode Threshold. Trigger longer sleep cycles if below this and hope for sunlight.
    name: Battery Saving Threshold
    icon: mdi:battery-alert
    optimistic: true
    min_value: 10.0
    max_value: 80.0
    step: 5.0
    restore_value: true
    initial_value: 20.0
#Low water tank threshold. Don't water if below this.
    name: Low tank water threshold
    icon: mdi:water-remove-outline
    optimistic: true
    min_value: 0.0
    max_value: 20.0
    step: 5.0
    restore_value: true
    initial_value: 10.0
button:
#Deep sleep if "allowed".
    name: Sleep If Allowed
    internal: ${internal_mode}
    icon: "mdi:sleep"
    on_press:
      then:
         - if:
              - binary_sensor.is_on: stay_awake_sensor
            then:
              - logger.log: "Sleep requested but STAY AWAKE mode is on. Skipping sleep."
              - deep_sleep.prevent: deep_sleep_1
            else:
              - logger.log: "Sleep requested and ALLOWED. Going to sleep..."
              - deep_sleep.enter:
#Force Deep Sleep
    icon: "mdi:bell-sleep"
    on_press:
      then:
        - logger.log: "FORCE SLEEP requested...Going to sleep"
        - deep_sleep.enter:
#Long Sleep (part of battery saving mode)
    on_press:
      then:
        - logger.log: "LONG SLEEP requested...Going to sleep"
        - deep_sleep.enter:
            sleep_duration: ${long_deep_sleep_duration}
        #Reset culmulative light sesnor reset
binary_sensor:
#Low tank water alert
    name: Tank Level Ok
    device_class: moisture
    lambda: |-
      if (id(water_tank_level).state > id(low_tank_water_threshold).state)
          {return true;}
        else if (id(water_tank_level).state <= id(low_tank_water_threshold).state)
          {return false;}
        else
          return {};
#Data updates alert. I've had the lux/tof playing up. Seems to be when battery < ~ 40%
    icon: mdi:database-alert-outline
    device_class: problem
    entity_category: diagnostic
#Low Battery alert
    name: Battery Level Is Low
    lambda: |-
      if (id(batt_level).state < id(battery_saving_mode_threshold).state)
          {return true;}
        else if (id(batt_level).state >= id(battery_saving_mode_threshold).state)
          {return false;}
        else
          return {};
    on_press:
      then:
        - button.press: long_deep_sleep #Long deep sleep if battery low.
#Pump Sensor.
    name: Pump is On
    icon: mdi:water-pump
    device_class: running
    lambda: |-
      return id(pump).state;
#Data Update Sensors.
  #These were useful during dev. Might remove in prod.
  #All updated via other sensors.
#Moisture
#Battery Level
    name: Battery level updated
#Light
#Water level
    name: water level updated
#All
    name: Data updates done
    icon: mdi:database-refresh-outline
    lambda: |-
      return
      id(solar_plant_moisture_level_recieved).state &&
      id(batt_level_recieved).state &&
      id(irrigation_lux_recieved).state &&
      id(water_tank_level_recieved).state
    on_press:
      then:
            state: OFF
      #Log that updates are all done
        - logger.log:
            format: "All sensors updated after %.1f secs of uptime. Checking if watering is required"
            args: [ 'id(uptime_sec).state']
        - delay: 100ms
      #Water if required and allowed then go to sleep. Note watering will only happen if total system is healthy (by design).
        - if:
              and:
                #Check if our watering regime wants a water dose
                - lambda: return (id(watering_mode).state == "Wetting Mode");
                - binary_sensor.is_off: battery_level_is_low # Not in battery saving mode.
                - binary_sensor.is_on: tank_water_level_is_ok #Tank Water is ok
                - binary_sensor.is_on: auto_water_sensor #Auto water is enabled
            then:
              - logger.log: "Watering required and allowed"
              - switch.turn_on: pump
              - delay: ${pump_run_time}
              - delay: 1s
              - button.press: sleep_if_allowed
            else:
              - logger.log: "Watering not permitted!!.." #todo log reason?
#Deep sleep control
#A lot of my logic is remashes of:
  #https://www.wirewd.com/make/blog/esphome_sleep_modes
  #https://tatham.blog/2021/02/06/esphome-batteries-deep-sleep-and-over-the-air-updates/
#Import HA Deep sleep control
    internal: false #I want to know that everyone is talking to each other;)
    entity_id: input_boolean.keep_esps_awake_switch_ha
    icon: "mdi:sleep-off"
    on_press:
      then:
        - logger.log: "STAY AWAKE requested from HA. Preventing deep sleep"
    on_release:
      then:
        - logger.log: "STAY AWAKE TURNED OFF. Going to sleep..."
        - deep_sleep.enter:
#Import Auto Water control
    internal: false
    entity_id: input_boolean.auto_water_planty
    icon: "mdi:auto-fix"
script:
#Pump auto off timer
  - id: run_pump_for_pump_run_time
    then:
      - logger.log: "Running pump for ${pump_run_time}"
switch:
#Pump
  - platform: gpio
    pin: ${pump_switch_pin}
    internal: false
    restore_mode: ALWAYS_OFF
    on_turn_on: #Auto off timer. Flood protection.
      - script.stop: run_pump_for_pump_run_time # Stop any existing timers.
      - script.execute: run_pump_for_pump_run_time # Start new timer
#Control peripheral power (on solar power manager)
  - platform: gpio
    name: Power Peripherals
    pin: ${power_peripheral_pin}
    internal: true
    restore_mode: ALWAYS_ON #Power on when waking from sleep.
globals:
#For daily battery level change (below). i.e net energy production or loss.
#Globals survive deep sleep
  - id: previous_value
    type: float
    restore_value: yes
    initial_value: '0.0'
#Track end of day battery
    name:  End of Day Battery
    update_interval: never
    icon: "mdi:solar-power"
    accuracy_decimals: 3
    on_value:
      then:
        #Calculate change in end of day battery and publish to sensor
        - lambda: id(change_in_end_of_day_battery_percent).publish_state(x - id(previous_value));
        #Set previous value as current value.
        - lambda: |-
            id(previous_value) = x;
#Track daily changes in battery (i.e net solar production)
    name: Change in End of Day Battery
    icon: mdi:trending-up
    internal: false
#Uptime sensor
  - platform: uptime
    update_interval: 2s
    accuracy_decimals: 0
    unit_of_measurement: s
#For counting data updates recieved for each wake cycle.
#Manually updated via publishing from other sensors.
#Track Lux updates
    name: "Count Lux Updates"
    icon: "mdi:counter"
    unit_of_measurement: count
#Track ToF updates
    name: "Count ToF Updates"
#Track battery updates
    name: "Count Batt V Updates"
    icon: "mdi:counter"
# Time of Flight sensor  - i2c
#Powered via 5v
  - platform: vl53l0x
    i2c_id: vl53l0x_i2c_bus
    # setup_priority: 300
    internal: false
    address: 0x29
    timeout: 300ms
    #never
    # enable_pin: GPIO17 #Did not work: https://github.com/esphome/issues/issues/3644
    accuracy_decimals: 1
    unit_of_measurement: 'cm'
    filters:
      - multiply: 100 #Convert to cm
      - median: #Moving median to smooth noise.  Sample 5 points then push.
          window_size: 5
          send_every: 5
          send_first_at: 5
    on_raw_value:
      then:       #Push sensor update counter.
        - lambda: id(count_irrigation_tof).publish_state(id(count_irrigation_tof).state +1);
#Convert the ToF distance to a water tank level (% full)
  - platform: copy
    source_id: tof
    internal: false
    # icon: "mdi:battery"
    name:  Water Tank Level
    entity_category: ''
    filters:
      # Map from distance to % full. To calibrate.
      - calibrate_linear:
          - 3 -> 100
          - 19.5 -> 0
      ##Overide values less than 0% and more than 100%. Round to 0.5%.
      - lambda: |
          if (x > 100) return 100;
          else if (x < 0) return 0;
          else return ceil(x / 5) * 5;
    on_value:
      then:
          state: ON
# bh1750 Lux/light sensor
  - platform: bh1750
    i2c_id: bh1750_i2c_bus
      # - id: bh1750_i2c_bus
    # sda: GPIO25 #data > green wire
    # scl: GPIO27 #clock > blue wire
    # scan: true
  # - id: vl53l0x_i2c_bus
    address: 0x23
    filters:
      - median:  #Use moving median to smooth noise. Sample 5 points then send.
          window_size: 5
          send_every: 5
          send_first_at: 5
    on_value:
      then:
          state: ON
    on_raw_value:
      then:
      #Sensor update counter.
        - lambda: id(count_irrigation_lux).publish_state(id(count_irrigation_lux).state +1);
#Measure of total light per day. Poor persons DLI https://en.wikipedia.org/wiki/Daily_light_integral
  - platform: integration
    name: "Light per day"
    sensor: irrigation_lux
    time_unit: s
    unit_of_measurement: lux*s
    restore: true
#Notes:
#Voltage divider: Used 2 x 300K Ohm resistors
  - platform: adc
    internal: true
    pin: ${batt_voltage_pin} #ADC1
    accuracy_decimals: 2
    attenuation: auto
    filters:
      # #Scale it back up from voltage divided value 2 x 300K > 2.1. 4.2/2.1 = 2.
      - multiply: 2
    on_raw_value:
      then:
        - lambda: id(count_batt_voltage).publish_state(id(count_batt_voltage).state +1);
#Intermediate sensor. Might consolidate them later.
  - platform: copy
    source_id: batt_voltage
    icon: "mdi:battery"
    internal: false
    unit_of_measurement: V
    filters:
          window_size: 10
          send_every: 10
          send_first_at: 10
#Convert the Voltage to a battery  level (%)
  - platform: copy
    source_id: batt_voltage_filtered
    internal: false
    icon: "mdi:battery"
    filters:
      # Map from voltage to Battery level
      - calibrate_linear:
          - 3.1 -> 0 #Set 3.0 to 0% even though it can go lower (2.4V), for life extention. There's not much capacity below this anyway.
          - 4.1 -> 100 #Set 4.05 to 100% even though it can go higher (~4.2V), for life extention.
      - lambda: |
          else if (x > 100) return 100;
    on_value:
      then:
      #Publish that data is recieved
          state: ON
#Capacitive soil moisture sensor: https://www.aliexpress.com/item/32832538686.html?spm=a2g0o.order_list.0.0.55771802WgNqEA
#Voltage of the Capacitive soil moisture sensor
  - platform: adc
    name: Soil Moisture Volts
    pin: ${soil_moisture_pin}
    internal: false
    # never
    attenuation: auto
    filters:
      - median:     #Use moving median to deal with noise. Sample 10, push 1.
          window_size: 10
          send_every: 10
          send_first_at: 10
#Convert the Voltage to a moisture  level (%)
  - platform: copy
    source_id: soil_moisture_voltage
    internal: false
    icon: "mdi:water-percent"
    filters:
      #max and min values taken from testing with glass of water. Prob need to do in-situ tests.
      - calibrate_linear:
          - 1.66 -> 100.0
          - 2.90 -> 0.0
      #Handle/cap boundaries
      - lambda: |
          else return (x);
    on_value:
      then:
      #Data update recieved.
          state: ON
      #Help manage the watering mode.
      #TODO: Monitor/test
       - lambda: |-
           if (x < id(moisture_lower_threshold).state)
              { return id(watering_mode).publish_state("Wetting Mode");}
           else if (x > id(moisture_upper_target).state)
              { return id(watering_mode).publish_state("Drying Mode");}
    on_value_range:
      - below: !lambda return id(moisture_lower_threshold).state;
        then:
          - lambda: return id(watering_mode).publish_state("Wetting Mode");
      - above: !lambda return id(moisture_upper_target).state;
        then:
          - lambda: return id(watering_mode).publish_state("Drying Mode");
This post is for content relating to itā€™s operation.
Iā€™ll start with a high level description. It essentially works very similar to other irrigation and deep sleep projects projects around:
  1. Wake up from deep sleep periodically and see if the plant needs water. If so, water, if not, back to sleep.
  2. Donā€™t water the plant if battery is low, instead, go back to sleep for a long time and hope you get recharged on next wake.
  3. Donā€™t water the plant if the tank level is low.
  4. The watering regime might be described as ā€œincremental drip-feed towards an upper target, followed by drying towards a lower thresholdā€. This lets the plant dry out a bit, then ā€œgives it a good water, but slowly rather than all at onceā€ā€¦ I still need to monitor that this is working ok.
  5. The light sensor is handy for checking how much light both the plant and the solar panel is getting.
Hi @Mahko_Mahko , how are you measuring the battery voltage? do you have a schematic?
Basically I built my first voltage divider.
Thereā€™s some details over here for it actually. But itā€™ll try to remember to tidy it up and add something here for it. It was harder to find simple info for it than expected. My final solution changed slightly to whatā€™s in this link.
I moved to using 2 x 300kOhm resistors. Itā€™s a simpler set-up. Thereā€™s also a few comments in my config about the resistors used and scaling/conversions.
Battery Monitoring
Summary:
  1. I made my first voltage divider. You need two resistors. I landed on 2 x 300kā„¦
  2. Wire them like below. I think itā€™s right. (Edit, Its not quite right as battery power should go to esp battery terminal) wanted to keep the diagram simple and didnā€™t want to draw up my full wiring yet. You just add extra wires for power and ground as you need for your other devices. Edit: best to see the wiring diagram now.
Longer version and resources:
  1. Article: ESP8266 battery level meter | ezContents blog 37,
  2. Thread: ESPHome Battery Level Sensor 48,
  3. Some help/checks from @ssieb over on Discord ,
From what I could understand the sum of the resistors should be high and the divided voltage should be < 2.4V
Which led me to my 2 x 300kā„¦ selection. I also like this ā€œsymmetricā€ design. Doesnā€™t matter which way you wire it.
Battery sensor snippet
#Notes:
  - platform: adc
    internal: true
    attenuation: auto
    filters:
      - multiply: 2
    on_raw_value:
      then:
  - platform: copy
    icon: "mdi:battery"
    internal: false
    filters:
          window_size: 10
          send_every: 10
          send_first_at: 10
  - platform: copy
    internal: false
    icon: "mdi:battery"
    filters:
      - calibrate_linear:
      - lambda: |
    on_value:
      then:
          state: ON
@Mahko_Mahko, Iā€™m trying to learn from your code, but I canā€™t really make it work. Iā€™m focusing on the deep sleep logic and Iā€™m trying to understand how it works.
as you can see my esp is ignoring the button to prevent deep sleep and the fact to sleep during the night, it constantly follows the cycle defined by the variables, in my case 30min sleep, 30min run
  run_duration: 30min
  sleep_duration: 30min
can you help me to understand what Iā€™m missing?
binary_sensor:
    entity_id: input_boolean.prevent_deep_sleep
    on_press:
      then:
        - deep_sleep.prevent: deep_sleep_control
    on_release:
      then:
        - deep_sleep.enter:
            sleep_duration: ${sleep_duration}
time:
    on_time:
      - hours: 20
        then:
          #Rest up
          - deep_sleep.enter:
              until: "06:00:00"
              time_id: homeassistant_time
deep_sleep:
  run_duration: ${run_duration}
esphome:
  on_boot:
    - priority: -100
      then:
        - wait_until:
              api.connected:
        - logger.log: "API connected"
        - wait_until:
              time.has_time:
        - logger.log: "Time has a value from Home Assistant"
        - if:
              binary_sensor.is_on: prevent_deep_sleep
            then:
              - logger.log: "Prevent deep sleep"
            else:
              - logger.log: "Allow deep sleep"
              - deep_sleep.allow: deep_sleep_control
  on_shutdown:
    priority: -100
    then:
      - if:
          then:
          else:
I had to work through some buggyness too at a few points.
Do you have any sensors with a high update_interval (say 1sec). Or are you managing the updates manually?
Try pulling them back to say 5sec for debugging.
Can you see the home assistant sensor being imported in the ESPHOME logs? Try making this NOT internal and check if it comes back re-imported into HA ok. So that it is clear everyone is hearing each other.
I also seem to recall sometimes the input Boolean only seemed to start working once you had toggled it from HA once the esp was online (once). So maybe fiddle with that.
In summary, Iā€™m not sure. Mine is working great but I recall having to work through weird issues.
did you get any success? Have the same issue
@Mar1us, almost
Iā€™m now able to prevent deep sleep with the button, but when It enters in deep sleep on sunset it never resume :frowning: still study/test/fail/learnā€¦
# Time configuration
time:
# Sun configuration
sun:
  latitude:  9999999999999  #replace with yours
  longitude: 9999999999999 #replace with yours
  on_sunset:
    then:
      - logger.log: "Sunset occurred, entering deep sleep mode until next sunrise"
      - deep_sleep.enter:
          sleep_duration:  !lambda "return id(sleep_duration_calc).state * 60;"
# Deep sleep configuration
deep_sleep:
  #run_duration: 5min # Run for 5 minutes before entering deep sleep mode
  #sleep_duration: 5min # Sleep for 5 minutes before waking up again
binary_sensor:
  # Get the state of the prevent_deep_sleep input_boolean from Home Assistant to control whether or not to enter deep sleep mode
  # Get the sleep_duration value from Home Assistant to control how long to sleep for in deep sleep mode
    entity_id: input_number.deep_sleep_sleep_duration
  # Get the delay_duration value from Home Assistant to control how long (in seconds) to wait before proceeding
    entity_id: input_number.deep_sleep_script_delay_duration
    name: "Sleep Duration to next Sunrise"
    unit_of_measurement: "min"
    lambda: |-
      if (id(tomorrow_sunrise_string).has_state() && id(today_sunset_string).has_state()) {
        struct tm tomorrow_sunrise_tm;
        strptime(id(tomorrow_sunrise_string).state.c_str(), "%Y-%m-%d %H:%M:%S", &tomorrow_sunrise_tm);
        time_t tomorrow_sunrise_time = mktime(&tomorrow_sunrise_tm);
        struct tm today_sunset_tm;
        strptime(id(today_sunset_string).state.c_str(), "%Y-%m-%d %H:%M:%S", &today_sunset_tm);
        time_t today_sunset_time = mktime(&today_sunset_tm);
        double sleep_duration_seconds = difftime(tomorrow_sunrise_time, today_sunset_time);
        return sleep_duration_seconds / 60.0;
      return {};
text_sensor:
    entity_id: sensor.suninfo_sunrise
    attribute: today
    internal: true
    entity_id: sensor.suninfo_sunset
    attribute: today
    internal: true
    attribute: tomorrow
    internal: true
    attribute: tomorrow
    internal: true
    lambda: |-
      if (id(today_sunset_string).has_state()) {
        struct tm t;
        strptime(id(today_sunset_string).state.c_str(), "%Y-%m-%d %H:%M:%S", &t);
        char buf[30];
        strftime(buf, sizeof(buf), "%B %d, %Y at %I:%M %p", &t);
        return std::string(buf);
      return {};
    lambda: |-
      if (id(tomorrow_sunrise_string).has_state()) {
        struct tm t;
        strptime(id(tomorrow_sunrise_string).state.c_str(), "%Y-%m-%d %H:%M:%S", &t);
        char buf[9];
        strftime(buf, sizeof(buf), "%H:%M:%S", &t);
      return {};
esphome:
  on_boot:
    priority: -10
    then:
      - logger.log:
          format: "Waiting for API to connect..."
      # Wait until API is connected and time is synchronized before proceeding
      - wait_until:
          api.connected:
      - logger.log:
          format: "API connected. Waiting for time to synchronize..."
      - wait_until:
          time.has_time:
      - logger.log:
          format: "Time synchronized. Checking prevent_deep_sleep binary sensor value..."
      # Check if the prevent_deep_sleep binary sensor value is on or off before proceeding
      - if:
            lambda: 'return id(prevent_deep_sleep).state;'
          then:
            - logger.log:
                format: "prevent_deep_sleep binary sensor value is on"
          else:
            - logger.log:
                format: "prevent_deep_sleep binary sensor value is off"
      # Log that API is connected, time is synchronized, and prevent_deep_sleep binary sensor value is checked
      - logger.log:
          format: "API connected, time synchronized, and prevent_deep_sleep binary sensor value checked."
      - wait_until:
          lambda: "return id(today_sunset).has_state() && id(tomorrow_sunrise).has_state();"
      - wait_until:
          lambda: "return id(prevent_deep_sleep).has_state() && id(sleep_duration).has_state() && id(delay_duration).has_state();"
      - script.execute: consider_deep_sleep
script:
  - id: consider_deep_sleep
    mode: queued
    then:
      - logger.log:
          format: "Executing consider_deep_sleep script"
      - delay: 10s
      - if:
          then:
            - logger.log:
                format: "Skipping sleep, per prevent_deep_sleep"
          else:
            - logger.log:
                format: "Entering deep sleep mode"
            - if:
                    - sun.is_above_horizon:
                        id: sun_component # Sun is above horizon.
                then:
                  - logger.log:
                      format: "Entering deep sleep until sunrise"
                  - deep_sleep.enter:
                      #sleep_duration: 2min
                else:
                  - logger.log:
                      format: "Entering deep sleep normal"
                  - deep_sleep.enter:
                      sleep_duration:  !lambda "return id(delay_duration).state;"
@Mar1us thank you, because after your message I provided more love to the code; it seems that now it works
  • The button to suspend deep sleep works
  • The input to control the deep sleep duration and the delay duration are working
  • The sunset condition seems ok (testing now)
essentially this is the behavior:
if the prevent deep sleep is on, the esp remains up
if the prevent deep sleep is off, it goes in deep sleep for the amount of minutes defined by the input sleep duration, then the script is delayed for the amount of time defined by the input number script delat duration. This is the normal condition, when the sun is below the horizontal then the esp goes in deep sleep until the next sunrise. (in order to calculate the sunst/sunrise duration I used the SUN2 component)
here the full code, testing it right now.
any feedback/comments is really apprecated
# Substitutions
# Define variables to be used throughout the configuration
substitutions:
  device_name: test
  friendly_name: "test"
  device_platform: espressif32
  device_board: nodemcu-32s
  device_ip: X.X.X.X
# Packages
# Include common configurations from external files
packages:
  wifi: !include common/device_wifi.yaml
  device_base: !include common/device_base_ESP32.yaml
  home_assistant_api: !include common/device_api.yaml
  sensor_wifi_ip_address: !include common/sensor_wifi_ip_address.yaml
# Enable logging
logger:
  level: VERBOSE
# API
api:
time:
# Sun configuration
sun:
  latitude: 999999
  longitude: 99999
  on_sunset:
    then:
      - logger.log:
          format: "Sleep duration until next sunrise: %f minutes"
          args: [ "id(sleep_duration_calc).state" ]
      - deep_sleep.enter:
          sleep_duration: !lambda "return id(sleep_duration_calc).state * 60000;"
deep_sleep:
binary_sensor:
    lambda: |-
      return {};
text_sensor:
    attribute: today
    internal: true
    attribute: today
    internal: true
    attribute: tomorrow
    internal: true
    attribute: tomorrow
    internal: true
    lambda: |-
        struct tm t;
        char buf[30];
      return {};
    lambda: |-
        struct tm t;
        char buf[9];
      return {};
esphome:
  on_boot:
    priority: -10
    then:
      - logger.log:
      - wait_until:
          api.connected:
      - logger.log:
      - wait_until:
          time.has_time:
      - logger.log:
      - if:
          then:
            - logger.log:
          else:
            - logger.log:
      - logger.log:
      - wait_until:
      - wait_until:
script:
    mode: queued
    then:
      - logger.log:
      - logger.log:
          format: "Delaying for %d minutes"
          args: [ "(int) id(delay_duration).state" ]
      - delay: !lambda "return id(delay_duration).state * 60000;"
      - logger.log:
          format: "After the delay"
      - if:
          then:
            - logger.log:
          else:
            - logger.log:
            - if:
                then:
                  - logger.log:
                  - logger.log:
                      format: "Sleep for %d minutes"
                      args: [ "(int) id(sleep_duration).state" ]
                  - deep_sleep.enter:
                      sleep_duration:  !lambda "return id(sleep_duration).state * 60000;"
                else:
                  - logger.log:
                  - logger.log:
                  - deep_sleep.enter:
thank you so much, that helped me a lot
Hi Folks, I would like to have your opinion here
Deep sleep cycle it fine to reduce the power consumption, but the ESP must remain on during the watering cycle.
how you calculated the battery capacity/pump consumption/solar panel?
Iā€™m looking around to select the hw
I think Andreas Spiess has done good videos on this (at least the solar and battery parts). You might need to search a bit on his channel.
For the pump youā€™d prob just measure current with a multimeter?
wow, what a good guidelines i found here. thank you!
i have one issue stillā€¦ how is possible to make component update for uart_bus?
Typically you use component.update on the actual sensor.
Do you have any electrical schematic and materials list here ? I am trying to create the same thing for my dying rose plants. Would be helpful.
Afraid not. I can do a materials list easy enough.
Schematic I can have a go at but will have to put aside some time.
I tried many schematics but end up burning something. Would be nice if I have them. Thank you
Materials List
1st pass at materials list. May not be complete yet. I included a few extra links to things like soldering equipment and crimping kit I have.
Component Notes Link
Single 18650 Battery Holder Cheap probably ok. Ali Express
3.7V 18650 Battery Buy a good one locally. Get like a 3000-36000mAH one. Get a protected one. Do a little research about local buying options.
Solar Panel (5V) Make sure you get the right voltage. I bought from this Ali Store
Sunflower: Solar Power Manager 5V Investigate your buying options. Core Electronics
Pump Do a little research on pumps and buy a slightly better one Ali Express
VL53L0X Ali Express
BH1750 Ali Express
L298n If you want pump flow control via PWM, you should get the full size version rather than the mini. Ali Express
2 x Resistors (300kā„¦) More detail here.
ESP32 LILYGOĀ® TTGO T7 Mini32 V1.5 Get a good ESP32 for this project. Get one optimised for low energy / deep sleep with battery connections. Tried other boards but idel current too high. Ali Express
Capacitive soil moisture sensor Water proofed with nail polish and hot glue. These are notoriously short lived so read up on them. Ali Express
Treated Pine Sleepers I made my ā€œcut planā€ and got Bunnings to cut to size. Bunnings
Decking Screws For fixing the base box together Bunnings
Castors To roll your plant around
Water Jerry Can To use as water tank. Bunnings
Glass food storage container with Plastic lid Consider your solar panel size when sizing this. KMart , IKEA
Flexible Silicone wire Ali Express
Crimping Tool & Kit ā€¦. ā€¦
Soldering equipment Ali Express
Very short usb cable Connect ESP32 and Solar Power Manager
Tubing Check / confirm the Internal diameter for compatibility with pump. Ali Express
3d printer To print irrigation rings plus other bits and bobs like ā€œcomponent mount plateā€.
Hot Glue Gun For mounting components Ali Express
Iā€™ve added a first cut materials list above.
Not sure when Iā€™ll get to doing a wiring diagram. Started one but I suck at them and struggle.
