Using ESPresent I am trying to get a sensor in HA that can show distance to my Apple watch. ESP32, MQTT broker/client, Apple IRK is working and I can see the sensor I make in config yaml, but I cannot get to work and show present and distance.
- ESPresense (espresense.com) runing on ESP32
- Sending MQTT telemetry to Home Assistant MQTT broker
– Apple Watch BLE distance detection (IRK has been setup)
- Telemetry data can be seen on Home Assistant MQTT browser
MQTT Home Assistant browser
Message 0 received on espresense/devices/irk:1234567890abcdefghijklmnopqrstuv/stue at 11:03 AM:
"id": "irk:1234567890abcdefghijklmnopqrstuv",
"disc": "0b18a48b30",
"idType": 200,
"rssi@1m": -65,
"rssi": -59,
"raw": 0.5,
"distance": 0.62,
"speed": -0.01,
"mac": "7fe37b9e7dcf",
"interval": 312
config YAML
- platform: mqtt_room
device_id: "irk:1234567890abcdefghijklmnopqrstuv"
state_topic: "espresense/devices/irk:1234567890abcdefghijklmnopqrstuv/stue"
timeout: 10
away_timeout: 120
In Developer Tools / States the sensor can be seen, but the state is “not_home” and distance is “null” (see below)
Filter enterties:
sensor.kudahl_apple_watch
Filter states:
not_home
Filter attributes:
distance: null
friendly_name: Kudahl_Apple_watch
For some reason the ”state” and ”distance” get set faulty in on ‘mqtt_room’ sensor. I made a workaround to use until I find the root course.
Changed the sensor in config yaml to a topic that does not get updatet
state_topic: "espresense/devices/no_device"
timeout: 10
away_timeout: 120
Made pyton script that change “state” and “distance”
inputEntity = data.get('entity_id')
inputStateObject = hass.states.get(inputEntity)
inputState = inputStateObject.state
inputAttributesObject = inputStateObject.attributes.copy()
newState = data.get('state')
if newState is not None:
inputState = newState
newDistance = data.get('distance')
if newDistance is not None:
inputAttributesObject['distance'] = newDistance
hass.states.set(inputEntity, inputState, inputAttributesObject)
Made a automation that listen for mqtt event of my apple watch and set the “state” and “distance” og the sensor.
alias: MQTT
description: ""
- platform: mqtt
topic: espresense/devices/irk:1234567890abcdefghijklmnopqrstuv/stue
service: python_script.set_state
data_template:
entity_id: sensor.kudahl_apple_watch
state: ON
distance: {{ trigger.payload_json.distance }}
Now I can use the sensor in a dashbord and it get updated
I can get distance for my apple watch, but the values are all around 1. I’ve tried absorption extremes, as well as decreasing the signal strength calibration to -35db. Little changes. Do you get reasonably accurate distances now? Thanks
I get distance and RSSI readouts, also > 1 meter. My 1-meter setting is about -55 dBm
- It is slow to get initial distance (due to it has to connect to get IRK)
- The distance is slow to apdapt to movement, (due to the filtering that is done on RSSI in the kernel)
- the RSSI/Distance is fluctuating quite a bit, but settles after a while, if Apple watch is stationary
I wonder if the newest watches with Bluetooth 5.3 are problematic dues to variable signal strength.
I have change the RSSI to as high as 30. I get very fast distance changes.
I did not anticipate the implementation problem of a multistory house. The only way I may be able to use these devices is very local. For example, is the watch on the nightstand.
