I have a couple of eps32 with espresense installed.
In the espresense config set up, is it possible to add some extra functions.
I have added dht11 to one of them, and I get the humanity and temperature. But when I add a ads7830 and a photoresistor to pin 21 and 22, I can’t get any data, not in mqtt explorer or in HA.
What do I have to to more, to get some data?
Then
If I want to use the button function and add something to for example pin 13. How do I set up HA, so I can use the button to set ON / OFF to the pin.
Theres a whole documentation section on the espresence website. It tells you righ at the top of the page, which sensors are supported and clearly your sensor isnt listed there so, perhaps thats why you arent seeing any data returned, ya?? Reading the documentation shouldnt be seen as optional and if you would have, you would have answered your own questions.
If I use the switch / button function, I need a psychical button to push so the electricity will get through or not (ON/OFF).
and
If I use the LED function, I get a state value, that I can change to ON/OFF via HA
but can I somehow change (toggle) the pull up/pull down value on the button/switch function so I get its value permanent via psychical button?
I can change the value ON OFF via MQTT
When I push my psychical button which I have connect to pin 12, the switch will change to switch = ON. When I release it, it turns back to switch = OFF.
If I publish via mqtt explorer I can change the state to switch = ON (without pushing psychical button)
and when I push my psychical button, it returns to switch = OFF
What I want to do:
switch = OFF
Push psychical button switch = ON. It will be ON until I push my button again, then it will turn back to switch = OFF
Parallel, I will have a input_boolean so when switch = ON my input_boolean turns on and start a automation. If I turn input_boolean off, I want my switch to change to switch = OFF without push the psychical button.
So the problem is its acting like a momentary button and you want it to act like a locking switch? It really helps if you know the lingo lol. I havnt personally tested the button or switch features in espresence since its relatively new but traditionally the difference between a button and a switch is a button is momentary and a switch is locking, so a switch will stay On after you let go and a button will turn off if its not being pressed. They have specified both button and switch so id assume this is how they already work. Is this not the case or are you mixing them up?
For the moment, I only have a push button and try out with.
So I did a input_boolean, so when it is on, it activate a script which send a mqtt message ON and when input_boolan turns off, another script to send mqtt message OFF.
I did this automation, probably not the most beautiful one, but it works.
Thats weird they have a switch and a button but they both work the same, ill have to play with one of mine and see whats going on. We all started at the beginning and didnt know anything but, the workaround you did to fix it tells me youll do just fine with this stuff. If it helps, you can make a latch switch from a momentary switch by making a simple circuit. Here is a guide
