I feel like this has to be user error, but for the life of me I cannot figure out where it is. I am attempting to set up my watch and my phone with ESPresnse, phone works fine, watch is always not_home.
I have added the phone and the watch following the instructions here. The watch being the more “complex” one because you have to grab the irk
manually, which I believe I got right because it shows up in the /ui
interface and in mqqt under espresense/devices
. I also added the watch to use a config setting like the phone, which correctly updated the key in espresense/devices
to be justin_watch
instead of irk:da....
– looks just like the phone and the json documents are AFAICT the same between the phone and the watch. Found this GH issue which confirmed this should work as well.
For the life of me though, I cannot figure out why Home Assistant is not recording the room my watch is in.
- platform: mqtt_room
device_id: justin_watch
state_topic: espresense/rooms
timeout: 10
away_timeout: 120
device_id: justin_phone
timeout: 10
away_timeout: 120
is the config I am using, phone correctly shows:
The watch only shows:
I’m sure it is something with my config, just not finding it since I copied/pasted from working to not working and just replaced “phone” with “watch”. Rubber ducking typing this out didn’t lead me to any brilliant ideas that fixed it, hopefully someone else has some ideas for me to look at.
Thanks for the eyes!
