Don’t tell me off for cross posting, just thought it was something which was related to HA but also maybe fixed over in the firmware of espurna
I just opened a bug report over on the github page for espurna, see:
https://github.com/xoseperez/espurna/issues/1273
The HA config for this config is actually suggested in the web page for the bulb, like this:
- platform: mqtt
state_topic: LEDBULB02/relay/0
command_topic: LEDBULB02/relay/0/set
payload_on: 1
payload_off: 0
availability_topic: LEDBULB02/status
payload_available: 1
payload_not_available: 0
brightness_state_topic: LEDBULB02/brightness
brightness_command_topic: LEDBULB02/brightness/set
rgb_state_topic: LEDBULB02/rgb
rgb_command_topic: LEDBULB02/rgb/set
color_temp_command_topic: LEDBULB02/mired/set
white_value_state_topic: LEDBULB02/channel/3
white_value_command_topic: LEDBULB02/channel/3/set
The error i get in the HA log file implies some issues possibly parsing the “LEDBULB02/rgb” value which inside MQTT is getting set to “#FF7F00”
So i guess the line we need to fix is:
So what should it be ?
Thanks!
