Hi everyone
I’m attempting to estimate my water usage in the front yard with simulated pulse meter sensor.
I currently have my sprinklers setup to be controlled with esphome. I’m now trying to set the rate and total usage via lamda when a value turns on then turn back to zero when the valve turns off. The rate works as expected the total does not increment and returns to 0 when the valve turns off.
Here is my current yaml for the sprinklers.
captive_portal:
time:
- platform: sntp
web_server:
port: 80
sprinkler:
- id: lawn_sprinkler_ctrlr
main_switch: "Frontyard Sprinklers"
auto_advance_switch: "Frontyard Sprinklers Auto Advance"
reverse_switch: "Frontyard Sprinklers Reverse"
multiplier_number: "Frontyard Sprinkler Multiplier"
repeat_number: "Frontyard Sprinkler Repeat"
valve_overlap: 10s
valves:
- valve_switch: "Zone 1"
enable_switch: "Enable Zone 1"
run_duration_number:
name: "Zone 1 Run Duration"
unit_of_measurement: min
initial_value: 5
valve_switch_id: lawn_sprinkler_valve_sw0
- valve_switch: "Zone 2"
enable_switch: "Enable Zone 2"
name: "Zone 2 Run Duration"
initial_value: 5
valve_switch_id: lawn_sprinkler_valve_sw1
- valve_switch: "Zone 3"
enable_switch: "Enable Zone 3"
name: "Zone 3 Run Duration"
initial_value: 5
valve_switch_id: lawn_sprinkler_valve_sw2
- platform: pulse_counter
name: "Water Rate Estimate"
pin: D2
unit_of_measurement: 'gal/min'
#internal_filter: 100ms
update_interval: 30s
accuracy_decimals: 2
filters:
- lambda: !lambda |-
if (id(lawn_sprinkler_valve_sw0).state ) {
return 3.5;
} else {
return 0;
total:
name: "Water Usage Total Estimate"
unit_of_measurement: "gal"
device_class: water
state_class: total_increasing
filters:
return 3.5;
} else {
return 0;
switch:
- platform: gpio
pin: D5
- platform: gpio
pin: D6
- platform: gpio
pin: D7
any thoughts or advice is very appreciated.
