I’ve confirmed the symbolic link /dev/zwave is functioning correctly after disconnect and reconnecting the stick.
So here is where I’m struggling with:
I haven’t been able to get the zwave stick to mounted to the docker container.
Docker Container Name = homeassistant
Zwave Stick = /dev/zwave
I will then need to figure out how to get HA to recognize it as my controller, but I’ve added the lines to the config yaml in preparation for this.
zwave:
usb_device: /dev/zwave
Background:
I’ve used ESXi and Ubuntu for quite some time.
I’m new to docker and new to HA.
I’m currently using Vera as a home automation system.
Vera doesn’t not have a good way of implementing SSL and it requires access to the cloud to utilize all of its features.
My goal with HA is to have a secure home automation environment.
I tried HA a little while back using the Vera component, but was unsuccessful at getting any automation function to work in HA, so now I’m trying a fresh approaching using a AeoTech ZW090 Gen 5 Stick.
HA had quite a bit errors that I ran into when ever I pushed updates to the server, so I decided to give docker a try as it sounds like that would resolve that issue and if I even wanted to move this environment to a Raspberry Pi or even a Windows Environment, then it makes that process a lot easier, from what I understand…
So, I believe it hass.io.
Though, I’m not quite familiar with the differences.
Yes, the USB Stick has been passed through from ESXi into the Ubuntu VM.
I confirmed this by checking for /dev/ttyACM0 using ls /dev/tty*
So, now I need to pass the USB Stick from the Ubuntu VM into the Docker container.
I open to alternative suggestions, I just know I had issues with the python virtual environment deployment when I updated the system.
As much as I enjoy learning from troubleshooting and problem solving, I don’t seem to have the time to devote to it anymore and I’m just looking to find a solid solution, that requires minimal up keep.
Interesting. So the /dev/zwave symbolic link didn’t come through under the “Hardware” button, but /dev/ttyACM0 did… When I run bash on the Docker Container and check the for it under /dev I see the ttyACM0, but not the zwave symbolic link as well… Maybe I don’t need the symbolic link?
To my config file… I had to move it around until the HA didn’t report an error on reboot…
** (I <3 yaml) – Yes there is a double space before usb_… ( not sure why I can’t get that to show up here… )
I was able to pair a device… confirmed with openhab (that i was testing on a separate VM)
It seems like HA might still not be seeing or initialize the AeoTech stick properly…
Is there a way to check if it has properly accepted and initialized the stick.
From what I was reading I should get a new panel on the main window that say something to the extent of Zwave Network/Devices…
Here is the HA log:
root@server:/# cat ./usr/share/hassio/homeassistant/home-assistant.log
2018-11-15 05:53:35 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Z-Wave (import from configuration.yaml) for zwave
File “/usr/local/lib/python3.6/site-packages/openzwave/option.py”, line 78, in init
raise ZWaveException(u"Can’t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: “Zwave Generic Exception : Can’t find device /dev/zwave : [‘NoneType: None\n’]”
File “/usr/local/lib/python3.6/site-packages/homeassistant/config_entries.py”, line 244, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/zwave/init.py”, line 283, in async_setup_entry
config_path=config.get(CONF_CONFIG_PATH))
File “/usr/local/lib/python3.6/site-packages/openzwave/option.py”, line 81, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /dev/zwave : ['Traceback (most recent call last):\n', ' File “/usr/local/lib/python3.6/site-packages/openzwave/option.py”, line 78, in init\n raise ZWaveException(u"Can\'t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n', 'openzwave.object.ZWaveException: “Zwave Generic Exception : Can\'t find device /dev/zwave : [\'NoneType: None\\\\n\']”\n']’
Since I was semi-testing with openhab on another VM…
I was able to confirm the device did pair with the AeoTeck stick…
I shut down that VM before starting the Hass VM…
And double checked that hass.io docker is still seeing the /dev/ttyACM0
I’m not sure why it’s still trying to referring to the /dev/zwave that’s no longer in the config file.
Maybe that was from when I previously tried to use it?
