hello,
is there a easy way to calculate time in minutes when battery will be charged?
i can imagine a algorithm, where I will create a sql sensor, which returns SOC value 15min ago, and calculate the time in template sensor.
any other ideas?
hello,
any other ideas?
you can check this thread for ideas:
Im using this sql query to get the seconds for one percent charging
select
(select last_updated_ts from states where entity_id = 'sensor.e3dc_battery_percent' and state != 'unknown' order by last_updated_ts desc limit 1)
- (select last_updated_ts from states where entity_id = 'sensor.e3dc_battery_percent' and state != 'unknown' order by last_updated_ts desc limit 1,1)
as time_percent
and a template sensor that estimates the time when battery is charging, else āunknownā.
sensors:
e3dc_batt_loading_end:
value_template: >
{% set remain = 100 - (states('sensor.e3dc_battery_percent') | int(0)) %}
{% set timepercent = states('sensor.e3dc_time_batt_percent') | int(0) %}
{% if states('sensor.e3dc_battery_power') | int(0) > 0 %}
{{ (as_timestamp(now()) + remain * timepercent) | timestamp_custom('%H:%M', true)}}
{% else %}
unknown
{% endif %}
Simple and not accurate, but iām happy with it.
here is finally my solution, iām considering percentage increase in last 5min
sql sensors with ālastā value and time
sql:
- name: wattsonic_battery_soc_5min_state
db_url: !secret URL_MariaDB
query: >
SELECT round(state, 1) as state, FROM_UNIXTIME(last_updated_ts) as updated from states
where entity_id = 'sensor.wattsonic_battery_soc' and
state != 'unknown' and
last_updated_ts <= UNIX_TIMESTAMP(NOW())-5*60
ORDER BY last_updated_ts DESC LIMIT 1
column: "state"
- name: wattsonic_battery_soc_5min_last_updated
query: >
SELECT state, FROM_UNIXTIME(last_updated_ts) as updated from states
column: "updated"
sensor
wattsonic_battery_soc_eta:
friendly_name: Wattsonic Batter SOC ETA
value_template: >
{% set battery_SOC = float(states("sensor.wattsonic_battery_soc"), default=100) %}
{% set battery_SOC_last = float(states("sensor.wattsonic_battery_soc_5min_state"), default=0) %}
{% set timediff = (states.sensor.wattsonic_battery_soc.last_updated.timestamp() - as_datetime(states("sensor.wattsonic_battery_soc_5min_last_updated")).timestamp())/60 %}
{% set percdiff = battery_SOC - battery_SOC_last %}
{% set percmissing = 100-battery_SOC %}
{% if battery_SOC>99: %}
full
{% elif percdiff<=0: %}
discharging
{% else %}
{% set timemissing = (percmissing / (percdiff/timediff))|round %}
{{ as_local(as_datetime(as_timestamp(utcnow()) + timemissing*60)).strftime("%Y-%M-%d %H:%M") }}
{% endif %}
it looks working
iām only wondering why this doesnāt work: state_attr(āsensor.wattsonic_battery_socā, ālast_updatedā)
but this yes: states.sensor.wattsonic_battery_soc.last_updated
