I received this card (WT32-ETH01) and I want to make a mini WIFI access point with access to the local network, is this possible?
The basic configuration is OK, my card works fine in ethernet.
I would like to do this
Local Network → WT32-ETH01 (Ethernet) → Wifi AP (WT32-ETH01) → ESP01 Wifi (Access to the Local network)
In addition, it is not possible to use the wifi component at the same time but in any case it will not work like this because the connection would give access to the Web Server of the WT32-ETH01 card and not to the local network.
It is possible, I have it working on a Gl.inet GL-S10. There is an example in the ESP-IDF example folder. It gets about 30Mb/s throughput. Not configured with ESPHome though.
