Ethernet + WiFi - speed test
Hi
I connect to raspberry pi 3 with an ethernet cable.
Where I do some speed test via the HA I received the ethernet speed.
how I check also the wifi speed connection?
Your WiFi is only relevant on your local network. For what reason do you want to test your wifi speed?
Yes ofcourse we talk about local network .
Because the LAN speed differs between WiFi speeds
if for example my phone connect with WiFi and have some internet connection/router problem i want to see it. and check the WiFi speed. its more lower the Ethernet connect for sure
But your HA server’s Wifi connection is going to be different than your phone’s, simply by the nature of how Wifi works. Running a “wifi test” on your HA server is going to yield different results than a phone sitting next to it.
Basically the test would be worthless.
I know this is not what you are specifically after but in case you are interested … the “speedtestdotnet” integration can periodically test your broadband speed. I have been having problems with my speed dropping at certain times and have been using this to run a test every hour which can be displayed on a graph.
