I’ve bought a cheap rf433 motion detector from a copany called etiger. I’m sure it’s some chinesium re-brand.
When I trigger the sensor I receive a bunch of signals, is this normal or do I need to active a setting in the rfxcom ?
Hi.
Which device did you use to make the server (on a pi?) receive 433Mhz data?
Were you using the RFXtrx433E USB HA controller
Can you share your final yaml for having the readings?
