EU Power Strip with local/offline connection and energy monitoring
Hi, I’m looking for a power strip with 3 or more sockets and USB ports. It needs to have energy monitoring and be able to control each socket individually. Wi-Fi (local/offline) or Zigbee (best).
I’m okay if it can be flashed using Tuya-Converter (without disassembling the device, etc.).
It looks like there is a big problem with this kind of device (to find them). I have bought the Tapo P300 and it works great, except there is no power metering.
A good place to look in are the supported devices in zigbee2mqtt with filters and there I found this LELLKI WP30-EU control via MQTT | Zigbee2MQTT
But if energy is really important you can also put a single plug with monitoring in front of the strip.
I had a Ledvance powerstrip with 3 Shuko plugs and 2 USB connectors.
It ran Tuya, but could be managed through LocalTuya.
Each Shuko plug could be monitored, but the USB plugs acted as one plug for turn on/off and monitoring.
I am not much for Tuya and I could not see that it was Tuya when I bought it, but it was an extremely low price, due to a clearance sale.
The fact that it is Tuya is enough for me to not recommend it, but others might accept Tuya devices.
Tasmota power strip.
https://www.amazon.de/Tasmota-Power-Strip-USB-Hub-WiFi/dp/B0054PSH9C
