EU Wall Socket with Power Consumption Measuring
I have a few Gosund SP112 around the house, but unfortunately they do not fit everywhere(they should be placed behind some furniture, but there just isn’t space)
I have tried searching already, but nothing really came up, so I am asking here:
Does anybody know if there is an EU Wall Socket that can be controlled via Wifi(preferrably Tasmota) AND is able to measure Power Consumption?
None that it know off. But you could try to put a Shelly 1 PM behind the existing wall outlet.
Thanks, that seems a bit big, so I would probably need to dig a bit deeper into the wall.
I did some more research and found the Blitzwolf BW-SHP8, which might be a good fit for me and apparently it is possible to do OTA update with tuya convert. I will check it out and report back.
Sorry to necro this post, were the blitzwolf sockets the solution you ended up going with?
How did they work out?
No I did not go for that. I am using a gosund p1 powerstrip instead, because I had a powerstrip anyways to connect all my PC stuff.
I replaced the powerstrip with the gosund p1 which i flashed with tasmota and that works pretty well.
alright, fair enough!
That won’t work for me unfortunately so I guess I’ll keep looking
Shelly plug s?
